Koni ride height clip
Old Oct 7, 2006 | 10:10 AM
lude1888's Avatar
Default Koni ride height clip
I just installed my koni's and neuspeed springs and found the height to be really high compared to the neuspeed springs and gr-2 struts. I noticed that there is a spot for the cir-clip to move the spring in a lower position. Is that what I am supposed to do or will that be too big of a gap for the springs.
Old Oct 7, 2006 | 10:16 AM
lude1888's Avatar
Default Re: Koni ride height clip (lude1888)
Here is a pic and as you can see there is a clip where the spring holder sits on and then below it is another spot to move that clip to, anybody put it there or should I?
Old Oct 7, 2006 | 12:20 PM
avallach's Avatar
Take one of the wheels off, jack the vehicle up and take picture of the shock/spring assembly. Let us take a look.
Old Oct 7, 2006 | 01:02 PM
clemsoncb7's Avatar
I actually have the same question except I am using ground control coilovers. But yea, can you just relocate the clip one level down?
Max
Old Oct 7, 2006 | 06:05 PM
user 9782082308's Avatar
Default Re: Koni ride height clip (maxvtec7500)
Put the spring seat on the koni and measure the difference from the lca bolt hole to the seat. Do this for the gr2's too. The gr2 seat will likly fall between to of the koni's circlip grooves. Once you have the diff you'll have to decide wheather your springs are stiff enough or the roads smooth enough to set the circlip in the lower position. I use the upper circlip groove to keep the extra shock length lowered Ludes so desperatly needs.
Old Oct 7, 2006 | 06:18 PM
Halo's Avatar
You can put the circlip on the lowest level to lower your car the lowest..good point of reference here
https://honda-tech.com/zerothread/1106020
Old Oct 8, 2006 | 11:50 AM
lude1888's Avatar
So with the springs on the koni strut on the upper level clip it is about 2 in higher than before with neuspeed and gr-2. I am going to go ahead and move it down to the lower position. If anyone can think of a reason not too, please let me know.
Old Oct 8, 2006 | 12:27 PM
avallach's Avatar
racerx told you the reason why you should NOT do this. The lower you go, the less travel you get out of your dampers. If your roads are smooth, then move it to the lower indent, just know you are taking away the the same amount of travel by doing this.
Old Oct 8, 2006 | 12:33 PM
clemsoncb7's Avatar
Is there any special way to remove these clips so as not to bend then or warp them? or are they pretty sturdy and retain their shape? Thanks
Max
Old Oct 8, 2006 | 12:38 PM
avallach's Avatar
They're fairly tough, I wouldn't worry about bending them. Get a flat-head screwdriver and move one end of the clip out of the groove, then do the same on for the other end. You'll end up scratching the shocks, but it shouldn't be to bad. Use some lubricant to slide the circlip down to scratch less.
Old Oct 8, 2006 | 05:04 PM
M@'s Avatar
M@
Default Re: Koni ride height clip (avallach)
2 inches higher is way higher then just a little. Either those origional struts were some kinda lowering strut, or you did something wrong.
My guess is you did something wrong like put the spring cup on upside down. If thats the case DON'T DRIVE.
2 in is way too much to be acceptable
Old Oct 8, 2006 | 06:21 PM
TheWalrus's Avatar
yeah sounds to me like the perch is upside down, i almost made that mistake when i put mine together.
Old Oct 8, 2006 | 06:30 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any special way to remove these clips so as not to bend then or warp them? or are they pretty sturdy and retain their shape? Thanks
Max</TD></TR></TABLE>
I used a piston ring spreader. Its also a good idea to get new cir-clips if you've been driving on the original ones for a while.
Old Oct 8, 2006 | 07:44 PM
clemsoncb7's Avatar
Default Re: Koni ride height clip (mkazm83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">I used a piston ring spreader. Its also a good idea to get new cir-clips if you've been driving on the original ones for a while.</TD></TR></TABLE>
My circlips have never been used, I still have the konis in the box just waiting to put them on and then this question came up. Should I still pick up some new circlips?
Max
Old Oct 8, 2006 | 08:06 PM
ludecz's Avatar
I'm using those Koni's with Eibach Sportline, first time I put them on I moved the c-clip on the bottom and the cup upside down (lower), it handled great on the track, but very loud bangs on some potholes or uneven streets. Two weeks later oil started to leak from the adjuster and on the other one the adjuster didn't move at all. So when I replaced them I left the C-clip in the midlle and left the cup upside down, bought new bump stops and trimed them (the original changed to dust). That is the best setting for me low enough for track/ comfortable for street and no problems.
Old Oct 8, 2006 | 08:09 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">My circlips have never been used, I still have the konis in the box just waiting to put them on and then this question came up. Should I still pick up some new circlips?
I think you'll be fine.
Old Oct 8, 2006 | 08:30 PM
lude1888's Avatar
thanks guys your right I did put the spring seats upside down. Now I have to go take it apart again and flip it. I was wondering why the springs weren't form fitting and moving around a bit.
kevinm1981
Suspension & Brakes
18
Jul 10, 2010 02:05 PM
jspeceg
Suspension & Brakes
Jul 23, 2008 05:29 PM
slow_ls
Suspension & Brakes
Aug 22, 2006 08:45 PM
Showoff
Apr 1, 2003 08:45 PM
4glude
Oct 25, 2002 07:25 PM
