Valve lash adjustment = amazing
Old Oct 7, 2006 | 07:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Valve lash adjustment = amazing
So I did a valve adjustment last weekend on my brother's del Sol last weekend that he just got a few weeks ago, and every single valve clearance was grossly out of spec.
So I figured I'd check the clearances on mine because it had been awhile since I last adjusted them. Got to it this morning, went through every valve, and found only ONE valve (#3 exhaust side) that was out-of-spec, and it was just barely loose, maybe .009 instead of .007
I went back and checked my records, last time I adjusted my valve clearances was 26K miles ago, August of last year, at 211,000 miles. Today I'm almost at 237,000 miles, and only one valve was just barely loose. I couldn't believe it.
And when I say all the rest were in-spec, I mean .006 would go in on the intake side, but not the .007. The .007 would go in on the exhaust side, but not the .008. That's how I check and adjust mine, and I like to keep them on the tighter end of the range to help keep valvetrain noise in check as much as possible.
Made for a quick job for sure. Just wanted to share.
fwdupree
Jun 1, 2018 12:13 PM
supersize
Jul 26, 2010 11:50 PM
Robotoyaki
Jan 1, 2010 02:10 PM
CRXSi90
Jun 23, 2009 07:19 PM
redpeppers
Jul 26, 2005 02:33 PM
