Whats a reasonable dealer charge for a 98 Accord LX 4cyl. timing belt & auto trans fluid change?
I guess the title "says" it all. I just got a 98 Accord 4 cyl. automatic. What a way TOO COOL car! I'm gettin 30MPG on the HWY....and lovin every minute of it!
Anyhow... it's at 91K and from reading this forum, the timing belt & trans fluid should be changed. Whats a reasonable dealer price for these 2 services? I just HATE goin to the dealer for anything! Thnaks very much!
400 for timing belt, 100-125 for ATF
or you can go to other shop that use OEM material for more discount
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">400 for timing belt, 100-125 for ATF
or you can go to other shop that use OEM material for more discount</TD></TR></TABLE>
I pay the dealership 50$ for my atf changes. I paid 600 for my timing belt on my 99 V6.
You'll generally pay around $700 anywhere you take it. Keep in mind though, this is not just the timing belt. They replace everything needed at this mileage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASWORD »</TD></TR><TR><TD CLASS="quote">
I pay the dealership 50$ for my atf changes. I paid 600 for my timing belt on my 99 V6.</TD></TR></TABLE>
timing belt with the new water pump and seals?
you guys have no idea how easy it is to do a timing belt change on a honda, on my mom's dodge or my gf's new bug, you have to do it with a lift
Do The Trans Yourself, Its Just like Changing the oil
Take out the plug Let it drain, Clean off the end of the plug (it has a magnet on the end)
Put the plug back in, Fill it Back Up with New fluid, About 4 Qts, I usually Put in a bottle of lucas transmission fix, then 3 quarts
Its so easy
Its so easy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro »</TD></TR><TR><TD CLASS="quote">
Lucas is crap. Stop using it.
Two400
Jan 22, 2008 04:10 PM
