Dpfi to mpfi Ls Swap Questions!
Old Oct 6, 2006 | 05:41 PM
mr_hahn73's Avatar
Default Dpfi to mpfi Ls Swap Questions!
How do I do this swap with the Obd0 pr4, Obd0 distributor but using the stock B18b Obd1 injectors and clips. Converting to Obd1 is not an option at this point! Can I split the dual point injector power wires to the four injectors without the resistor box?
Old Oct 7, 2006 | 01:23 AM
ALLMOTORCRX20's Avatar
Default Re: Dpfi to mpfi Ls Swap Questions! (mr_hahn73)
If your going to stay obd-0 and drop in the LS motor, then you will need the injector clips for an obd-0 crx, civic or integra and the injectors too. You will also need the resistor box.
Old Oct 7, 2006 | 11:19 AM
crxnj's Avatar
Default Re: Dpfi to mpfi Ls Swap Questions! (ALLMOTORCRX20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_hahn73 &raquo;</TD></TR><TR><TD CLASS="quote">How do I do this swap with the Obd0 pr4, Obd0 distributor but using the stock B18b Obd1 injectors and clips. Converting to Obd1 is not an option at this point! Can I split the dual point injector power wires to the four injectors without the resistor box?</TD></TR></TABLE>
mpfi conversion is not the hard-&gt;http://fourthgenhatch.net/mpfi.html
with those obd1 injectors you dont need a resistor box at all since they're saturated
br8crumb
Jun 1, 2014 10:00 AM
surkitroller
Dec 29, 2009 12:58 PM
shauniewalnuts
Nov 22, 2004 07:15 PM
civicefdx
Oct 24, 2004 03:25 PM
dpine
Jul 14, 2004 06:19 PM
