I am doing this swap regardless of what people think
Old Oct 6, 2006 | 12:03 PM
projectomegaspeedworks's Avatar
Default I am doing this swap regardless of what people think
ok I am putting a sr20 motor into a 88-91 civic hatch. I understand that there is easier swaps but im not going for the bolt in approach. I have the full ability to customize this swap but I have ran into some design issues that I would like to try to clear up before I start this winter project. Ok so the only problem that is apparent is clearing my steering rack seems impossible how can i get around this. I have all the rear wheel conversion figured out its not a problem. I have room for my rad and shifter. the gas tank is relocated. I will whip up a custom carbon fiber hood. keep in mind that I can make anything fit on this car. any help would be aprreciated. thanks.
Old Oct 6, 2006 | 12:04 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: I am doing this swap regardless of what people think (projectomegaspeedworks)
Why not use a FWD SR motor?
Good luck for a crazy *** fab project keep us in the loop and tons and tons of pics
Old Oct 6, 2006 | 12:09 PM
Default Re: I am doing this swap regardless of what people think (Capt. Blonde Beard)
because i am trying to make a name for myself and the shop i work out of. I dont want this to be easy. as far as all my research has returned nobody has ever pulled this off ( well as far as the internet is concerned ). and yes i will have picks of every step of the way.
Old Oct 6, 2006 | 12:11 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectomegaspeedworks &raquo;</TD></TR><TR><TD CLASS="quote">because i am trying to make a name for myself and the shop i work out of. I dont want this to be easy. as far as all my research has returned nobody has ever pulled this off ( well as far as the internet is concerned ). and yes i will have picks of every step of the way.</TD></TR></TABLE>
I still think the FWD will be enough a hassle but an extra to you for going all out.
Old Oct 6, 2006 | 12:17 PM
Kalokohan's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">Why not use a FWD SR motor? </TD></TR></TABLE>
+1 on the Bluebird SR. Even swapping this in a Sentra is no walk in the park. I think an SR in an EF is stupid, there are many other ways to be different without being stupid.
To the poster, I know you are going to do it regardless of what we say but actions speak louder so post pictures of your project. Until then, I call BS.
Old Oct 6, 2006 | 12:19 PM
Default Re: I am doing this swap regardless of what people think (Kalokohan)
yes this is an exessive amount of fabrication for one project. so call it bs or whatever the hell you want but this will be done in one way shape or form. so be patient and wait for photos. still waiting on a decent shell. and motor but this car will be on the streets come june. its just a matter of time.
Modified by projectomegaspeedworks at 6:02 PM 10/6/2006
Old Oct 6, 2006 | 12:21 PM
Outsane's Avatar
with those serious fab skills you have,
maybe able to toss in the steering set up from an EP
but then you may have already that of that..
Old Oct 6, 2006 | 03:11 PM
markviiisvt4's Avatar
I've seen this done as well as a rear drive 13b rex just do yourself a favor and tube it. If your not BS'in
Old Oct 6, 2006 | 05:04 PM
Default Re: (markviiisvt4)
ok where have you seen this done and any pics would be greatly appreciated.
thanks
Old Oct 6, 2006 | 05:24 PM
jhota's Avatar
what's the problem with the rack?
Old Oct 6, 2006 | 05:48 PM
Default Re: I am doing this swap regardless of what people think (jhota)
the largest part of the bell housing runs right where it sits stock.
Modified by projectomegaspeedworks at 7:24 PM 10/6/2006
Old Oct 6, 2006 | 05:52 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
No offense, but anyone with the skill/means/knowhow to make this work would not get on Honda-Tech.com and ask how to do it. IMO, if you are dead set on doing a FR setup, use the S2K drivetrain. I'd respect you a lot more, and it'd have as much power as that SR all motor. It's been done, but it takes a lot of money/time/skill.
Old Oct 6, 2006 | 07:57 PM
E_F_9's Avatar
This thread will die out in a few days and we'll only hear about an SR crx when someone says "Hey,remember that guy who said he was going to make a RWD SR powered crx?"
Old Oct 6, 2006 | 08:09 PM
highrev1987's Avatar
sr20 out of a bluebird, pulsar or "s'" chassis?
sounds like fun either way
also will it be a T
Old Oct 6, 2006 | 08:26 PM
SIred91's Avatar
Rainman
if you are doing this regardless of what people think you wouldnt bother posting this horseshit either.....
The bullshit flag is a'wavin..
Old Oct 6, 2006 | 08:31 PM
Tippyman's Avatar
If you are actually doing this, post pics.
Old Oct 6, 2006 | 08:33 PM
Wes V's Avatar
Default Re: I am doing this swap regardless of what people think (highrev1987)
Just use a Pinto rack and place it in front of the engine, fab up a steering shaft for it. (standard street rod stuff!)
You will have to modify the spindles for the attachment of the steering ball-joints, but that shouldn't be that hard in light of all the other stuff you think you can pull off.
You've said that you want to do the project in order to make a name for your self. Why not put together something that others would like to see.
I'd rather see a K motor in the back of a CRX done cleanly! Pay to have the rear suspension geometry designed by a professional. Then go out and do laps against a Lotus Elise.
If you could match the handling, I'd be impressed.
Wes
Old Oct 6, 2006 | 09:00 PM
CRX_1.8T's Avatar
Default Re: I am doing this swap regardless of what people think (Wes V)
You should just do a mkIV Supra engine instead if you are going to hack the heck out of the car and make it rwd.
Entire clips are just above $3k.
Old Oct 6, 2006 | 09:11 PM
loosestool's Avatar
Default Re: I am doing this swap regardless of what people think (CRX_1.8T)
sounds like a headache to me. You sound pretty confident so good luck. I hope who ever is involved with this swap has knowledge of frames/unbodies and lining up of drive shaft/pinion angles etc.
I too have the knowledge to pull something like this off but probably wouldnt...If I decided to fab something it would probably be a 51 merc led sled. Your swap if complete will get some serious publicity but hardcore Honda and Nissan guys wont like it. Imagine puting a 351w in a tri five chevy
Modified by loosestool at 10:31 PM 10/6/2006
Old Oct 6, 2006 | 09:20 PM
TEAM JDM-P's Avatar
Default Re: I am doing this swap regardless of what people think (loosestool)
well a shop i know allready did a 4g63 on an eg an was a waste of time dont think the SR will be any different
Old Oct 8, 2006 | 11:33 AM
Default Re: I am doing this swap regardless of what people think (NO-NAME)
thanks Wes V for actually answering with some contributing info. this will work i beleive. and to all the hecklers see you next summer.
Old Oct 8, 2006 | 01:09 PM
nuckingfuts's Avatar
if you know everything about it and "can make anything fit on this car" why are you asking about it?
good luck nonetheless
Old Oct 8, 2006 | 01:14 PM
KillSwitch's Avatar
Default Re: I am doing this swap regardless of what people think (nuckingfuts)
if u can make anything fit in any car than why are you asking questions on honda-tech? ur lame......
Old Oct 8, 2006 | 01:20 PM
Default Re: I am doing this swap regardless of what people think (tuybotom)
because i dont know what steering rack would fit or the steps to take to make one fit elsewhere. maybe I have brutal short term memory but I dont remember posting that I am a genious that knows it all. Because I dont but I do have an extremely good idea of what needs to happen on this build. the steering was the only cloudy question. I have the answers i need thanks for everyones imput.
Old Oct 8, 2006 | 01:32 PM
h224thgensedan's Avatar
k on your side i have seen an sr20 in a del sol a while back for sale on ebay. The guy said it was an absolute pita. If your going to run fwd imagine the fun linkage ,mounts ,axles and clearances are going to be. RWD isnt going to be a cake walk as well. The easiest way to do it just like everybody else said is tube it.
Personally i wouldnt do it. If i was good at fabracation i would do something like Wes V said and throw a motor in back make it look clean and out handle most anything.
