ls v-tec
Old Oct 6, 2006 | 09:06 AM
bflan2001's Avatar
Default ls v-tec
i tried to search the forums but because of the search words it doesn't pull up any results...anyway, i'm wondering what the advantages are of going with an ls v-tec setup rather than a normal b18 v-tec setup?
Old Oct 6, 2006 | 09:15 AM
Eran's Avatar
HT White Ops
Are you high?
an LS motor is a B18B. B18-VTEC = LS-VTEC.
And as for the advantages of LS-VTEC over a B18C1, basically, cost. It's cheaper to find an OBD1 LS motor and then get yourself a GSR head and B16 tranny.
Old Oct 6, 2006 | 09:19 AM
JDM_EK_wanabe's Avatar
Default Re: ls v-tec (bflan2001)
cost is cheaper
and you will have a slightly higher torque than the gsr
if you are using the ls tranny you will have slightly beter gas milage too becuase they have taller gears, at least 4rth and 5th that i know of
Old Oct 6, 2006 | 09:26 AM
SkoundrelUSA's Avatar
cute little bastard
LS block is much cheaper
LS block has an 89mm crank compared to the 87.2mm crank of the GSR/ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boocivic &raquo;</TD></TR><TR><TD CLASS="quote">
if you are using the ls tranny you will have slightly beter gas milage too becuase they have taller gears, at least 4rth and 5th that i know of</TD></TR></TABLE>
Yeah but you're going to be alot slower compared to someone with a B16/ITR tranny
Old Oct 6, 2006 | 09:27 AM
keanevann2005's Avatar
check out this thread.....
https://honda-tech.com/zerothread?id=1519455
its just a compilation of ls/vtec info
Old Oct 6, 2006 | 09:35 AM
bflan2001's Avatar
please excuse my ridiculous newb-ness, but are you guys saying that an ls-vtec is the same thing as a regular vtec engine? i thought it was a non-vtec integra ls block with a gsr head?
i'm going to be putting all this into an early 90s honda civic hatch
and does the b16 tranny have closer gears??
thanks for the help so far guys, if you ever have any questions about A4s, i'm your man
Old Oct 6, 2006 | 09:39 AM
G2 Speed's Avatar
Default Re: (bflan2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bflan2001 &raquo;</TD></TR><TR><TD CLASS="quote">please excuse my ridiculous newb-ness, but are you guys saying that an ls-vtec is the same thing as a regular vtec engine? i thought it was a non-vtec integra ls block with a gsr head?
thanks for the help so far guys, if you ever have any questions about A4s, i'm your man </TD></TR></TABLE>
b16 has much closer gears, but you will suffer in mileage and I belive some topend.. best combo is b16 tranny with ls 5th..
Old Oct 6, 2006 | 09:45 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bflan2001 &raquo;</TD></TR><TR><TD CLASS="quote">please excuse my ridiculous newb-ness, but are you guys saying that an ls-vtec is the same thing as a regular vtec engine? i thought it was a non-vtec integra ls block with a gsr head?</TD></TR></TABLE>
Essentially yes. With the right internals/build, an LS/V can even be considered better than stock B-series engines
Yes much closer compared to an LS tranny.
Why do A4's suck so much? j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">
b16 has much closer gears, but you will suffer in mileage and I belive some topend.. best combo is b16 tranny with ls 5th..</TD></TR></TABLE>
Mileage isn't that bad. Only complaint I have about my tranny is that I can't keep up with people sometimes on the highway because I don't want to cruise at 6k rpms
Old Oct 6, 2006 | 09:48 AM
G2 Speed's Avatar
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Essentially yes. With the right internals/build, an LS/V can even be considered better than stock B-series engines
Mileage isn't that bad. Only complaint I have about my tranny is that I can't keep up with people sometimes on the highway because I don't want to cruise at 6k rpms</TD></TR></TABLE>
mileage is awful, I remember being in my buddies b16a2 swapped hatch..
He's at like 120km/h, at 4500rpm
my d16y8, 140km/h at 4000rpm
Old Oct 6, 2006 | 09:52 AM
cute little bastard
Default Re: (G2 Speed)
oh I thought you meant gas mileage. Mines like 25mpg
Old Oct 6, 2006 | 11:11 AM
pat92si's Avatar
gas mileage will suffer and you would be at 4k rpm's doing roughly mph. i would suggest the LS 5th gear swap if your on the highway alot.
Old Oct 6, 2006 | 11:30 AM
Superdragr45's Avatar
Default Re: (pat92si)
the LS/VTEC wont be as reliable as a factory built GSR/ITR motor....................
no oil squirters as well soo the bottom end will take a lot more punishment and the LS bottom end is not made to spin past 7500rpm................
also, as with any frankenstein motor, it will have its share of running issues and tuning is a must to get the power out of this particular motor
some good parts of this motor are the added torque and the cost...............mine ran a 14.6@97mph in a 99 EK coupe................also, i would get any VTEC tranny soo it will not drop out of VTEC..........
Old Oct 6, 2006 | 02:18 PM
bflan2001's Avatar
thanks guys...a couple more questions..
what parts would i need to replace on the ls block to make it as reliable as the regular vtec block?
also, is an auto-manual conversion doable? i've found a couple auto civics, but since i'm doing a motor/tranny swap i was hoping it wouldn't matter?
LAST question (for now anyway), does anyone have a good link that explains OBD ports and mixing parts from different gens?
Old Oct 6, 2006 | 02:44 PM
cute little bastard
good thread
https://honda-tech.com/zerothread?id=1676914
Old Oct 6, 2006 | 04:59 PM
bflan2001's Avatar
AWESOME, thanks for the links guys, you guys are the mans!
Old Oct 6, 2006 | 05:40 PM
G2 Speed's Avatar
Default Re: (Superdragr45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">i would get any VTEC tranny soo it will not drop out of VTEC..........</TD></TR></TABLE>
That's acctually a really good point
zenon8890
Dec 22, 2005 10:31 PM
97teggLS
Jun 1, 2004 08:20 AM
whiteknightef
Mar 30, 2004 10:00 AM
integra81
Nov 22, 2001 04:11 PM
