Front forks fact or fiction!
Old Oct 6, 2006 | 05:36 AM
mustbenu1's Avatar
Default Front forks fact or fiction!
i need new front forks on my crx so i did some searching and many people and websites said the 90-93 integra forks are the same. So i bought a pair off ebay. They dont look anything alike, whats up?
heres pics of the crx forks i found
heres a pic of the 90-93 integra forks
Old Oct 6, 2006 | 06:01 AM
Boosted Chemist's Avatar
Default Re: Front forks fact or fiction! (mustbenu1)
i knwo the opening is wider to allow the b series axles to be removed without taking the forks of.
Old Oct 6, 2006 | 06:09 AM
mustbenu1's Avatar
are they the same height and the opening up top is the same diameter to accept crx shocks.
Old Oct 6, 2006 | 07:21 AM
EL Vap133's Avatar
You were better off getting 92-95 Civic forks.
Old Oct 6, 2006 | 07:22 AM
crx2nr822's Avatar
Default Re: Front forks fact or fiction! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You were better off getting 92-95 Civic forks. </TD></TR></TABLE>
X2
Old Oct 6, 2006 | 07:58 AM
EL Vap133's Avatar
Default Re: Front forks fact or fiction! (crx2nr822)
BTW, how could you not find the forks? I see them all the time at the junkyard I go to.
Old Oct 6, 2006 | 08:33 AM
Pooper's Avatar
I"m pretty sure that the teggy forks are bigger. I have tanabe sustec pros on my rex but they are off of an integra. My forks would not work because the diameter
of the integra shock were larger.
Old Oct 6, 2006 | 08:54 AM
EL Vap133's Avatar
Default Re: Front forks fact or fiction! (Pooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooper &raquo;</TD></TR><TR><TD CLASS="quote">I"m pretty sure that the teggy forks are bigger. I have tanabe sustec pros on my rex but they are off of an integra. My forks would not work because the diameter
of the integra shock were larger.</TD></TR></TABLE>
Oh no doubt they are, and the curviture is a bit different.
Old Oct 6, 2006 | 09:24 AM
mustbenu1's Avatar
check this link scroll down to almost the bottom
here is a quote from it:
http://www.ef-honda.com/ben/EFhybridsus.php
The EF and DA forks are exactly the same and so are the EG and DC and all 4 of them have the same height (no matter what anyone tells you). EF/DA fork on left, EG/DC fork on right:
is that wrong?
Old Oct 6, 2006 | 09:30 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (mustbenu1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu1 &raquo;</TD></TR><TR><TD CLASS="quote">check this link scroll down to almost the bottom
is that wrong?</TD></TR></TABLE>
They might be same lenght but as posted above
Oh no doubt they are, and the curviture is a bit different. </TD></TR></TABLE>
That is 110% true.
So I would say that is correct info from the site but misleading.
Old Oct 6, 2006 | 09:47 AM
EL Vap133's Avatar
Sure they can be the same height, but the diameter of where the shock goes in is different for sure.
mustbenu1
Suspension & Brakes
Oct 6, 2006 10:25 AM
beaneg6
Sep 12, 2005 06:35 AM
soloteg
May 5, 2004 10:45 AM
Grease Monkey
Dec 18, 2003 08:01 AM
solorexer
Oct 9, 2001 04:10 PM
