bounce problems with Coil Overs
Old May 2, 2002 | 02:33 PM
abeaujuin's Avatar
Default bounce problems with Coil Overs
I have a 95 accord I installed a set of Coil Overs on my car with the original shocks. The car looks good dropped, but it bounces like crazy. How can this be fixed?
[Modified by abeaujuin, 4:42 AM 5/3/2002]
Old May 2, 2002 | 02:36 PM
Accord94DX's Avatar
Default Re: bounce problems with Coil Overs (abeaujuin)
Your shocks are blown. Replace Them.
Old May 2, 2002 | 04:23 PM
urbantrain's Avatar
Default Re: bounce problems with Coil Overs (Accord94DX)
yup, blown struts.. i recommend kyb gr2's nice and cheap replacements, and a very stiff ride.
Old May 2, 2002 | 04:27 PM
SOHCArchangel's Avatar
with like some good shocks, koni's, bilstein, kyb agx.....
Old May 2, 2002 | 07:09 PM
RJonathan's Avatar
Yeah sound like your shock is got dude. You should get some Tokico Illumina or Koni Yellow. Those shock should fix up the problem right away...
Old May 2, 2002 | 07:44 PM
abeaujuin's Avatar
But the shocks were fine with the original springs. I don't understand. Can someone explain?
Old May 2, 2002 | 07:46 PM
Accord94DX's Avatar
Sure. Dropping a Car shortens the travel of the shock rod and places more stress on the internal components. You might have bottomed out right after lowering the car and that alone is enough to blow the stock shocks. OEM Shocks were never meant to handle to stress of a lowered car.
Old May 2, 2002 | 07:52 PM
ArchAngel Sabastian's Avatar
New User
Default Re: bounce problems with Coil Overs (SOHCArchangel)
depending on how far you drop kyb's only good too 1.25 drop.
Old May 2, 2002 | 08:04 PM
abeaujuin's Avatar
When I installed the Coil Overs The Top cap that bolts on to the chasis never connected in other words when I jack up the car the spring is very loose. I can move it up and down with no problems It is not like how the stock was all together. Even when I ajust it to the very limit of length it is still very loose.
Old May 2, 2002 | 08:07 PM
Accord94DX's Avatar
thats normal with coilovers.
Old May 2, 2002 | 08:11 PM
Nick M's Avatar
Koni Yellows
Nick- who has Koni yellows and loves them
Old May 2, 2002 | 08:16 PM
Accord94DX's Avatar
Default Re: bounce problems with Coil Overs (HondaSport)
Brian - Has koni yellows and loves them
Old May 2, 2002 | 08:19 PM
abeaujuin's Avatar
Cool I will replace them. What should I ask for when replaceing? I want to be able to ajust from 1-4, and I don't wont to spend alot of money.
aaronfunstuff
Mar 6, 2014 03:26 PM
SoullessJapaneseMachine
May 31, 2010 05:11 AM
corpuszerogtr
Jan 17, 2008 10:35 AM
95_civic_sparco
13
Nov 18, 2004 10:54 PM
vimsen
Aug 28, 2002 05:32 PM
