educate me on back pressure
Old Oct 5, 2006 | 07:47 PM
EK FLY's Avatar
Default educate me on back pressure
what the hell is back pressure why do we need it in a n/a car , sorry to ask such a lame question but in all my motors cars that i had I never get to learn what the heck is backpressure and what does the desing of the header make an impact in it
Old Oct 5, 2006 | 07:58 PM
Heylookits shawn's Avatar
Default Re: educate me on back pressure (super-hatch)
you dont want backpressure. you want higher exhaust velocity
Old Oct 5, 2006 | 08:00 PM
Rev2Eight's Avatar
Default Re: educate me on back pressure (Heylookits shawn)
so its not about how much air, rather how fast?
Old Oct 5, 2006 | 08:03 PM
AVA's Avatar
AVA
Sláinte
Default Re: educate me on back pressure (Rev2Eight_EM1)
dude imagine if you put 10" exhaust on a honda. the exhaust wouldnt get pushed out of the muffler it would just linger up in there. there has to be some restriction
Old Oct 5, 2006 | 08:07 PM
peacexisxfree's Avatar
Default Re: educate me on back pressure (^Jae)
you want a small amount of back pressure in an n/a car.
hold on while i find proof...
http://forums.evolutionm.net/p...38866
text from link below. i did not write this.
Contrary to common popular belief, a larger exhaust does not always result in better engine performance. There are situations where an engine could loose low-end torque from "too little" backpressure. I know it seems counter-intuitive to think that an engine actually needs a certain amount of backpressure but here's why. Most engines are set up from the factory for a certain level of backpressure. Changing the exhaust can create a situation where the cam has too much overlap for the RPM range it's being driven in. In that case, the incoming fuel/air will come in the intake valve, only to have part of it sucked straight out the exhaust valve without getting burned! Obviously, engine power will suffer if it doesn't get a full fuel charge to burn. Proper backpressure will prevent this. So will choosing a more appropriate cam for your RPM range, however.
There is another, more complex reason why 5" pipes on a normal sized naturally aspirated engine won't work. It isn't that the engine needs more backpressure, it's that static pressure is only half the equation. The equation for the "equivalent" pressure at the exhaust port is P-pv^2, the static pressure minus the exhaust density times the square of the exhaust velocity at the port. A 5" pipe may see a slight reduction in static pressure but will kill off the velocity making it harder to push the exhaust out. Some tuned header systems can make the exhaust velocity high enough that the engine effectively has a lower amount of backpressure than the atmospheric pressure! This is known as exhaust scavenging and is what separates good headers from bad ones.
In the case of a turbocharged car, everything is different. They can run a huge exhaust pipe, like the HKS 5" pipes and see a performance gain rather than loss. The reason is the turbine. The exhaust coming out of the cylinders only sees the velocity going into the turbine. The velocity drop across the turbine doesn’t effect flow. On a turbocharged engine, there is no need to worry about the exhaust velocity downstream of the turbine. The size of the header primary tubes and collector, or the exhaust manifold design, still plays a larger role in determining exhaust velocity, but the pipes downstream of the turbo are a lot less important.
As for the turbo itself, you want to maximize the pressure (and temperature) difference across the turbine for the highest efficiency. A low velocity of the gasses exiting the turbine won't make it any less efficient; in fact, it can theoretically improve the efficiency of the turbine. So the exhaust on a turbocharged car can be designed to minimize static pressure, without concern for the exhaust velocity.
So what does all of this mean? It means that while a 5" exhaust would be desirable for a 350 hp turbocharged Supra, it would be a very bad idea on a 350 hp naturally aspirated Camaro and an awful idea on a 1.8 liter naturally aspirated Honda.
Modified by peacexisxfree at 9:18 PM 10/5/2006
Old Oct 5, 2006 | 08:12 PM
Default Re: educate me on back pressure (peacexisxfree)
no. i didnt say the bigger the better, i said you want exhaust velocity, not backpressure
Old Oct 5, 2006 | 08:15 PM
his question was answered in that post.
i didn't say you were wrong.
Old Oct 5, 2006 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">his question was answered in that post.
i didn't say you were wrong.</TD></TR></TABLE>
nah i was referring to what someone else said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^Jae &raquo;</TD></TR><TR><TD CLASS="quote">dude imagine if you put 10" exhaust on a honda. the exhaust wouldnt get pushed out of the muffler it would just linger up in there. there has to be some restriction</TD></TR></TABLE>
Old Oct 5, 2006 | 08:27 PM
AVA's Avatar
AVA
Sláinte
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">nah i was referring to what someone else said</TD></TR></TABLE>
I didnt say you were wrong either. I was talking to rev light. lmao
Old Oct 5, 2006 | 08:28 PM
Old Oct 5, 2006 | 08:30 PM
Rev2Eight's Avatar
well i wasnt making any claims in my post so i didnt say he was wrong either. Most be the OP thats wrong
Old Oct 5, 2006 | 09:09 PM
junkyardTurbo's Avatar
you dont need backpressure in an all motor car. exaust velocity is what they mean. if you go too large with the piping the exaust gas of your car will slow down thus reducing the flow. how do you know that you dont need backpressure? get a 2.25 mandrel bent catback and try running a 2.25 inlet chambered muffler and a straight through. the straight through will make more power.
Old Oct 6, 2006 | 05:33 AM
Lsos's Avatar
Most engines are set up from the factory for a certain level of backpressure. Changing the exhaust can create a situation where the cam has too much overlap for the RPM range it's being driven in. In that case, the incoming fuel/air will come in the intake valve, only to have part of it sucked straight out the exhaust valve without getting burned! Obviously, engine power will suffer if it doesn't get a full fuel charge to burn. Proper backpressure will prevent this.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Some tuned header systems can make the exhaust velocity high enough that the engine effectively has a lower amount of backpressure than the atmospheric pressure! This is known as exhaust scavenging and is what separates good headers from bad ones.</TD></TR></TABLE>
So....too little backpressure is bad, but the less backpressure the better?
Old Oct 6, 2006 | 05:57 AM
Danziver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote"> There are situations where an engine could loose low-end torque from "too little" backpressure. I know it seems counter-intuitive to think that an engine actually needs a certain amount of backpressure but here's why. Most engines are set up from the factory for a certain level of backpressure. Changing the exhaust can create a situation where the cam has too much overlap for the RPM range it's being driven in. In that case, the incoming fuel/air will come in the intake valve, only to have part of it sucked straight out the exhaust valve without getting burned! Obviously, engine power will suffer if it doesn't get a full fuel charge to burn. Proper backpressure will prevent this.</TD></TR></TABLE>
Intresting
Old Oct 6, 2006 | 08:58 AM
hybrid_vtec's Avatar
Default Re: educate me on back pressure (Danziver)
Back pressure = bad juju
I think you guys are thinking of pressure waves which bounce back and forth through the piping. These can be helpful (pressure waves) if tuned for the specific area of the powerband that you want to utilize.
Other than that, you want free flow piping that is matched to how much air your engine can push.
Old Oct 6, 2006 | 10:33 AM
type B16's Avatar
just get a straight through exhaust that matches the header exit.
2.5 header collector get a 2.5 exhaust
Old Oct 6, 2006 | 12:27 PM
91SiZ6's Avatar
Default Re: educate me on back pressure (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Back pressure = bad juju
Other than that, you want free flow piping that is matched to how much air your engine can push. </TD></TR></TABLE>
Backpressure.
Properly matched exhaust flow velocity.
WanderingSamurai830
40
Mar 13, 2007 12:26 PM
lambo95
Dec 17, 2006 12:20 PM
jmouchett
Jun 2, 2005 10:52 PM
Turbo Powa
Jun 11, 2002 02:41 PM
onyx00
May 23, 2002 06:57 AM
