HELP cams wont line up HELP PLEASE!!!!!!!!!!!!!!!!
Old Oct 5, 2006 | 07:12 PM
DB1_559's Avatar
Default HELP cams wont line up HELP PLEASE!!!!!!!!!!!!!!!!
ok so i just did a head swap both ls head and the cam gears wont line up got the crank lined but the cam just wont line up need help asap tryed 10 times
ps 93 ls swap out for 95 ls and im useing the 93 ls cams gears can that be why it wont line up all stock
Old Oct 5, 2006 | 07:53 PM
gsr dood's Avatar
Default Re: HELP cams wont line up HELP PLEASE!!!!!!!!!!!!!!!! (jdmboi86)
make sure everythings at TDC before u start and the crank is on the white line.
Old Oct 6, 2006 | 09:58 AM
DB1_559's Avatar
i did put it at tdc but my cranks dont have the white marks just arrows which is hard to line up
Old Oct 7, 2006 | 02:29 PM
91turboteg's Avatar
there should be two little holes on the cams
you should bo able to put two little screwdrivers in the holes
or go buy the actual tool from honda don't know what it is called.
Old Oct 7, 2006 | 05:04 PM
Sam92Teg's Avatar
Default Re: HELP cams wont line up HELP PLEASE!!!!!!!!!!!!!!!! (91turboteg)
I think they call them 8mm dowel pins, but I use drill bits. The crank pulley has a white notch on it, look with a bright light, you will see it. There will be three other notches just to the left of it, and those are used later when you use a timing light on the pulley.
Line the white crank pulley line up to the lower cover pointer and have the cams set at TDC with the holes on the cams pointing up thru the cam holders. Then with the pins holding the cams straight, install the belt beginning on the exhaust cam, then the intake cam. It is a challenge to get it right the first time, but with practice you will see how it can be done. The tension from the valve springs on the cams also add a degree of difficulty.
Also only spin the crank counter clockwise three teeth observed on the cams after you install the belt to tension the belt and tighten the tensionor back up.
Old Oct 7, 2006 | 08:00 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">I think they call them 8mm dowel pins, but I use drill bits. The crank pulley has a white notch on it, look with a bright light, you will see it. There will be three other notches just to the left of it, and those are used later when you use a timing light on the pulley.
i did this but my crank dont have the white marks or any marks just the little line which is hella hard the get rite did it so much im getting good
Also only spin the crank counter clockwise three teeth observed on the cams after you install the belt to tension the belt and tighten the tensionor back up.</TD></TR></TABLE>
B18CUL8R
Oct 22, 2008 02:51 PM
10kEG
Aug 24, 2008 11:58 AM
7808
Jun 9, 2006 07:21 AM
lv6l
Nov 17, 2005 04:41 PM
balbowskie187
Apr 5, 2005 04:34 AM
