GSR front sway bar endlinks
Hey guys I searched but couldn't find a site to buy these from. I want from gsr sway bar endlinks and preferrably not the stealership. Any ideas?
http://www.barancoacuraparts.com has good prices. Len is very helpful.
$49.35
51320-ST7-003 LINK, FR. STABILIZER
Since the endlink is not the typical bolt/bushing/nut deal like the ITR bar, you really don't have a choice. However, if you can score on an ITR bar (same diameter as GSR) and sell the GSR bar, you can buy the ES endlinks.
http://store.summitracing.com/...w=sku
$49.35
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood »</TD></TR><TR><TD CLASS="quote">isnt the gsr 22mm and the type r 23 mm???</TD></TR></TABLE>
no u.s. itr and 96 spec jdm itr is 22 mm..98 spec jdm itr is 23mm.
gsr is like 16 or 14 or something around there dont remember
Yeah, just installed energy suspension swar bar bushings and end link bushins, but i was bugging out on the end links, cause i was only able to change the bushings, no the whole end link which is what i really needed to change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAPESTER »</TD></TR><TR><TD CLASS="quote">the gsr bar is 22mm? are u sure of that? </TD></TR></TABLE>
24mm
24mm
its 24mm. I think you guys are getting my post confused with a ITR rear sway bar. Im talking about the front sway bar. I thought the front sway bar for type r and gsr were the same, and those look like LS GS sway bar endlinks for the front? GSR one is L shaped.
The part number I gave you was for the GSR L-shaped one. But the picture I showed you was for the ITR bar. I was comparing to two.
