choking trying to rev...??? 91 hatch b18
Old Oct 5, 2006 | 07:03 PM
blazinrola7880's Avatar
Default choking trying to rev...??? 91 hatch b18
Sup fellas. my boys hatch has a lil problem. we did timing belt w-pump.and cai. new plugs. but now the cars actin up. ok if you drive it hit the gas it moves of not to strong. like be4, if you go to rev it it chokes up goes vrooom cut cut vroom cut cut wrooom redline....... we were thinking ither cat cloged or fuel filter. we tryed revin it and coverd the muffler and it didnt have enuff pressure to move my hand. also let say its ideling you head it poping and the engine is stock except for "intake". car has always gad a cel. lite on cpu blickes like 3-4 times stops.
could it be a vaccume problem he tryed eliminating the plstick cansiter by the tranny that a red hose goes to t/b
car is 91 hatch dx
swaped b18 a1.
Old Oct 5, 2006 | 08:09 PM
Jonknee's Avatar
Default Re: choking trying to rev...??? 91 hatch b18 (blazinrola7880)
Sounds like a map sensor problem, check that out.
Old Oct 5, 2006 | 10:17 PM
crxnj's Avatar
maybe you the timing is off after you did the timing belt,,,if its off a tooth it will have a low redline,and "pop"
Old Oct 5, 2006 | 10:19 PM
Tippyman's Avatar
check the code: http://www.c-speedracing.com/faq/05.php
Old Oct 11, 2006 | 06:47 PM
Default Re: (Tippyman)
ill check map sensor i dout timing cuz let say you go on my drive way its long and a lil inclinedand drop the clutch it will rev up.....
Spoolup98
Honda CR-V & Element
May 18, 2019 03:21 PM
GRIMRemembeR
Jul 25, 2012 12:46 AM
jasonbabin
Jan 18, 2011 05:25 PM
pimpwagon
Sep 6, 2010 09:42 PM
gassaversracing
Mar 13, 2009 05:58 PM
