K24A2???
i was going 2 use JE pistons wit 13.3 compression ratio... wht kind of rods should i use with this setup??? i knw the stock are forged steel will these hold up wit the pistons on is the 99mm stroke 2 much??? and also wht kind of octane should i run 4 reduce detonation??
Rods depends on your use. If you looking for the best/lightest rod then go with Cunningham. I would run at least 94 Sunoco, but a CR of about 13:1 or below would be safer.
