wheel bearing replacement
Old May 2, 2002 | 02:13 PM
Cow's Avatar
Cow
Default wheel bearing replacement
I'm pretty sure one of my wheel bearings is going bad and I was considering doing this myself. Has anyone else done it? How long/difficult is it? I was looking in my Helms and it says you have to have some special tools so I doubt I'll be able to do it but I wanted to check first. Also, do you have to remove the knuckle? Any advice/comments are welcome, thanks..
Oh yeah.. how long can you go on a bad bearing before something horrific happens (like say my wheel falls off at 70 mph)?
Old May 2, 2002 | 04:29 PM
SIK IN DA HED's Avatar
New User
Default Re: wheel bearing replacement (Cow)
if i were you, i wouldnt try drivin it too far. you can tell if you hear a ticking/squeal noise. i rather have someone do it. its a bitch doing the bearing. you would still have to take it to a shop to put on a new bearing anyway. usually it costs around $100+to get it done.
save yourself some labor money and take off the hub yourself. then take it to the shop for the bearing install.
[Modified by dlplayboy, 5:29 PM 5/2/2002]
Old May 2, 2002 | 05:42 PM
Padronis's Avatar
Default Re: wheel bearing replacement (dlplayboy)
Check my recent post. https://honda-tech.com/zerothread?id=175176
Edit- BTW Your wheel won't fall off, just lock up.
[Modified by G2LSS, 8:43 PM 5/2/2002]
thunderboy
Mar 20, 2009 12:15 PM
CivicVX94
Oct 15, 2007 05:42 PM
petergriffen
Aug 11, 2006 08:44 PM
FakeJDMEF8
18
Nov 22, 2005 08:13 PM
yung98gsr
Feb 18, 2005 09:28 AM
