cannot separate engine from tranny TRIED EVERYTHING
Old Oct 5, 2006 | 05:36 PM
petty$rep's Avatar
Default cannot separate engine from tranny TRIED EVERYTHING
Hey guys,
I am removing my manual transmission from my D16Z6 engine and I cannot get the two to separate.
I have tried everything, a BFH, it is impossible to use a pry bar because there is NO gap in between the engine and the tranny, I have tried wiggling it, shaking it, and twisting it.
I am using a engine hoist and a jack to remove the tranny.
Thanks,
AND YES I HAVE REMOVED ALL THE BOLTS
which includes all six of the bolts connecting the tranny to the engine
Old Oct 5, 2006 | 05:45 PM
petty$rep's Avatar
Default Re: cannot separate engine from tranny TRIED EVERYTHING (petty$rep)
ANYONE HAVE ANY IDEAS
petty$rep's Avatar
ANYONE??????????????????????????????????
Old Oct 5, 2006 | 06:23 PM
1fastVX's Avatar
Did you pull the starter? The two starter bolts also hold the tranny on.
John
Old Oct 5, 2006 | 07:18 PM
boostedblkef's Avatar
Default Re: cannot separate engine from tranny TRIED EVERYTHING (1fastVX)
x2 on the starter
also is the bolt going thru the motor into the trans removed
Old Oct 5, 2006 | 07:44 PM
deryck324's Avatar
try a bigger hammer and prybar
Old Oct 5, 2006 | 08:56 PM
Garage 808 Hatch's Avatar
#1 starter, but i belive there are more than 6 bolts, a couple from the block to the tranny
Old Oct 5, 2006 | 09:48 PM
lthao61's Avatar
Default Re: (Garage 808 Hatch)
dont forget to remove the ten mm and twelve mm bolts from under the tranny.
Old Oct 6, 2006 | 06:55 AM
SPITVENOM67's Avatar
Default Re: cannot separate engine from tranny TRIED EVERYTHING (Russell K.)
werd therer are more than six big bolts the 2 10mms under and 2 12mm I think but the started is prob wat is getting you once I was going nuts because I believe there are some that dont have the bolt soo long and that all I had worked on so I left it on, turns out it was that.. good luck
Old Oct 6, 2006 | 10:53 AM
Max Kling's Avatar
Clutch cover.
Old Oct 6, 2006 | 01:18 PM
d16dcoe45's Avatar
Default Re: (Max Kling)
I don't know if its on all z6 but my old 94 si had two seperated stiffeners connecting the trans to the motor (on the bottom). Also don't forget about the thin sheetmetal flywheel inspection cover, I believe there are two bolts on the trans for that and then two oil pan nuts/bolts connecting it.
rice a roni
11
Apr 26, 2006 05:10 PM
SuperDuude
10
Jul 1, 2004 09:24 AM
triggerX
Apr 24, 2004 12:03 AM
Inaniac
28
Oct 20, 2002 11:36 AM
AshlandSi
Oct 15, 2001 06:55 PM
