Horrible traction problems. Trapspeed 115Mhp (185kmh)
Old Oct 5, 2006 | 01:07 AM
calvinPGMFI's Avatar
Default Horrible traction problems. Trapspeed 115Mhp (185kmh)
I'm having horrible traction problems and wheelhop. I have to something about it.
I think I will buy: traction bars, m&h slicks, d2/amr/omni power coil overs.
I also have to fix my sychro 3rd gear.
I took my car for a test run.
E.t. 13.6 Trapspeed 116.8 mph/187 kmh.
Shouldn't I be 11 high/12 low with those trapspeeds.
CJ
Old Oct 5, 2006 | 05:56 AM
Honda Bull's Avatar
Default Re: Horrible traction problems. Trapspeed 115Mhp (calvinPGMFI)
Is this car turbocharged? Either way, you should be 12s definately. But invest some money into a nice set of slicks and you'll be much better off. But the slicks should be number one priority to dropping the times. Let us know what you do. Good luck.
Old Oct 5, 2006 | 06:51 AM
What is will do:
Qauife LSD
M&H slicks 24.5/8.5/15(legend brakes)
Traction bars
Old Oct 5, 2006 | 03:44 PM
Honda Bull's Avatar
Default Re: (calvinPGMFI)
Definately.
You probably won't need the traction bars as much as the other two, but go ahead and get them if you'd like them.
Old Oct 6, 2006 | 08:21 AM
raene's Avatar
Traction bars will help the most with wheelhop, also look into a bushing kit if you're still on stock bushings.
With more traction your trap speed tends to drop, I'd expect more like mid to low 12s with that setup
Old Oct 6, 2006 | 11:30 AM
Default Re: Horrible traction problems. Trapspeed 115Mhp (raene)
Thanks. drop me mail @ calvin@cjperformance.com for something.
I have energy suspension bushing all over the car.
CJ
I'll do:
Quife
Traction bars
M&H's
AMR coilovers
I just have to save some money
Modified by calvinPGMFI at 12:08 PM 10/8/2006
Old Oct 6, 2006 | 03:27 PM
blackpearlcivic's Avatar
How much boost pressure are you running?
Old Oct 6, 2006 | 11:20 PM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. drop me mail @ calvin@cjperformance.com for something.</TD></TR></TABLE>
Who me?
Old Oct 7, 2006 | 05:45 AM
vxhatched's Avatar
MOUNTS and TRACTION(Slicks will eliminate all that and do what you are looking for) Traction bars are a waste of money, I know unless you are going for 10's or 9's. You are wheel hopping cause your motor either is not staying still or your tire pressure is to high, and with a soft compound tire you will eliminate that, promise.
Old Oct 8, 2006 | 02:08 AM
Default Re: Horrible traction problems. Trapspeed 115Mhp (blackpearlcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlcivic &raquo;</TD></TR><TR><TD CLASS="quote">How much boost pressure are you running?</TD></TR></TABLE>
8.5 Psi
Last setup 81mm b16 gsr cams/62-1 turbo
273 whp on 7.5 psi
THis setup 84mm b16 ctr cams/62-1 turbo
xxx whp on 8.5 psi
Old Oct 8, 2006 | 02:09 AM
Default Re: (vxhatched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxhatched &raquo;</TD></TR><TR><TD CLASS="quote">MOUNTS and TRACTION(Slicks will eliminate all that and do what you are looking for) Traction bars are a waste of money, I know unless you are going for 10's or 9's. You are wheel hopping cause your motor either is not staying still or your tire pressure is to high, and with a soft compound tire you will eliminate that, promise.</TD></TR></TABLE>
I have energy suspension in my engine mounts. Enenrgy suspesion bushing all over the car.
I'll try the tire pressure.
Old Oct 8, 2006 | 08:04 AM
Honda Bull's Avatar
Most likely the wheel hop is being determined by the tire type you are running right now. Ask most of the guys running slicks and they'll tell you that wheelhop just doesn't happen often, if at all. I personally have had wheelhop once out of 45-50 runs on slicks.
Old Oct 8, 2006 | 12:54 PM
blackeg's Avatar
Default Re: (Honda Bull)
yeah i had wheel hop once out of abou 25 passes on drag radials. i said to myself wtf was that lol!
once you start getting traction your mph will go down a little bit. id expect that you are making in the 325whp range, and with around a 2.0 60ft time you should be able to get mid to low 12's depending on how much your car is weighing.
look in my sig for my information, we should be very close to the same #s in both track times and hp
Old Oct 8, 2006 | 01:18 PM
fmfkid250's Avatar
I went 11.87@118 on bfgs with 262 whp on a stock ls an *** mounts and no suspenion...i think the problem is behind the wheel...
more practice!!!
Old Oct 8, 2006 | 02:46 PM
blackeg's Avatar
Default Re: (fmfkid250)
im sure your car weighs barely 2200lbs w/o driver, and thats if you didnt do any weight redux.
my coupe weighs about 300lbs more than that w/o driver. weight has a lot do with it, so i needs to be taken into acct.
Old Oct 8, 2006 | 09:28 PM
Default Re: (blackeg)
I will run full slicks. We don't have any track byte on the track. It's a old air strip. Traction isn't that good
Old Oct 8, 2006 | 09:55 PM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">I went 11.87@118 on bfgs with 262 whp on a stock ls an *** mounts and no suspenion...i think the problem is behind the wheel...
more practice!!!</TD></TR></TABLE>
118 mph on 262 whp??? I believe either your car weighed in around 1750 lbs or the track was racing down a hill. But whatever. I wouldn't hark too badly on this guy. Most dragstrips in Europe just aren't as prepped as in the US.
Old Oct 9, 2006 | 06:42 AM
jep's Avatar
jep
get the slicks bro if anything. I have quaife lsd, full-race traction bars and h&r springs w/ tokico illuminas but I was wheel hopping like crazy on dunlops 205/40/17. the tires hopped at 25psi and 30psi. (i wanted to run the car in street trim just to see what it could do) I cant stress how important tires are. If you put one thing that could make the biggest difference, ITS TIRES. I would also urge u to get the full slicks and play with the tire pressure.
Old Oct 10, 2006 | 12:07 AM
Default Re: (jep)
ok i'll do
Old Oct 10, 2006 | 02:18 AM
Honda Bull's Avatar
Default Re: (jep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jep &raquo;</TD></TR><TR><TD CLASS="quote"> I cant stress how important tires are. If you put one thing that could make the biggest difference, ITS TIRES. I would also urge u to get the full slicks and play with the tire pressure.</TD></TR></TABLE>
In road racing and drag racing... tires are basically everything. Less so in drag racing, but you get the idea.
ALL IMPORT
Sep 7, 2006 05:35 PM
wleach11
Jun 21, 2005 12:12 AM
poorguy
Sep 19, 2003 07:32 PM
Adub33
15
Jul 10, 2003 04:18 AM
1 2 NV
40
May 31, 2003 09:04 AM
