88 hf : mpfi or dpfi
Old May 2, 2002 | 12:34 PM
tanjulio's Avatar
Default 88 hf : mpfi or dpfi
1988 crx hf, is it
1. multiport or dual port fuel injected?
i ask , because i recieved inconsistant data
2. if it is multiport, is it easy to add a zc engine.
i found a dx wiring conversion for zc, but nothing on hf
any info would be great..
Old May 2, 2002 | 01:10 PM
Trinity's Avatar
Default Re: 88 hf : mpfi or dpfi (tanjulio)
i belive its multi, i'm pretty damn positive thats probably why you haven't found anything
Old May 2, 2002 | 01:21 PM
Hayasa15's Avatar
Default Re: 88 hf : mpfi or dpfi (Trinity)
yeah an hf is mpfi but the head only has 8 valves compared to 16 per cylinder.
Old May 2, 2002 | 01:23 PM
EP3_05's Avatar
Default Re: 88 hf : mpfi or dpfi (Hayasa15)
I am pretty sure it is mpfi although the hybrid site says differently. The HF has 2 valves per cylinder as compared to the other models that have 4 per cylinder.
Old May 2, 2002 | 01:57 PM
jaje's Avatar
the 88-91 crx hf definitely did have mpfi (same as si)...however the hf has smaller axles than the si/dx crxs and you'll have to swap out the front knuckles/hubs/spindles to handle the larger axles
Old May 2, 2002 | 02:28 PM
USDM 4G VTEC's Avatar
the HF its MPFI BUT!!, the trottle body and intake manifold are smaller in diameter and size compared to a Si regular MPFI....
Old May 2, 2002 | 04:12 PM
Jeff 360's Avatar
16 per cylinder
Wow that's alotta valves per cylinder man
Old May 2, 2002 | 04:13 PM
89 CRX SI's Avatar
Default Re: 88 hf : mpfi or dpfi (Jeff 360)
16 per cylinder
hahahahaha yeah it is 16 per cylender they are 1mm vakves 10 intake 6 exhaust
Old May 2, 2002 | 04:36 PM
CimorelliCRX's Avatar
Default Re: 88 hf : mpfi or dpfi (89 CRX SI)
Yea, as they said its MPFI, and as you asked, will a ZC swap in, yea, right in.. You will need to get a DX or SI tranny, or even ZC. What youc an do is just swap part of the axles on the other ends of the si or DX. Or just buy the hubs and all, not too hard to change. Good luck.
SFlCrx
May 23, 2007 09:05 AM
classic69
Dec 17, 2005 05:21 AM
Serdar
11
Feb 21, 2004 11:54 AM
bluebullet
10
Jun 16, 2002 06:58 PM
