hissing sound with clitch engagement?
Old Oct 4, 2006 | 09:10 PM
cbmprelude's Avatar
* B A N N E D *
Default hissing sound with clitch engagement?
When I push my clutch pedal to the floor, there is a hissing noise that comes from the engine compartment. It changes in pitch and intensity depending on how far I push the clutch in. I first noticed this problem after driving through some quite large puddles during a recent heavy thunderstorm. Any ideas?
Old Oct 5, 2006 | 12:55 AM
92_VX_EG's Avatar
Default Re: hissing sound with clitch engagement? (cbmprelude)
It could be your throwout bearing. The puddles wouldn't have caused that to go bad, they go bad over time.
Old Oct 5, 2006 | 06:21 AM
poison's Avatar
Yup, sounds like throw-out bearing.
Old Oct 5, 2006 | 06:44 AM
AbitAvenger's Avatar
Default Re: hissing sound with clitch engagement? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Yup, sounds like throw-out bearing. </TD></TR></TABLE>
Old Oct 5, 2006 | 06:57 AM
instructor74's Avatar
Default Re: hissing sound with clitch engagement? (AbitAvenger)
It can also be the pilot bearing. It really doesn't make much of a difference as to witch on it is in order to replace them the trans has to come off so you might as well get a comp clutch kit and change everything at the same time
Old Oct 5, 2006 | 08:02 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: hissing sound with clitch engagement? (instructor74)
hmm, I just put in an excedy clutch and flywheel and bought a new pilot bearing. I wonder though about the throw-out bearing, I reused one that seemed to be in good condition. Is having a faulty throwout bearing going to affect daily drivablity other than excess noise? Will excess amounts of waterdamage the bearing?
Old Oct 5, 2006 | 08:14 AM
SOHCejcivic's Avatar
water didn't damge your to bearing. that's a lot of moving **** for water to make it past, and what little MAY have made it up there, wouldn't have done anything. how's it drive? any jumping/weird engagement?
Old Oct 5, 2006 | 12:15 PM
92_VX_EG's Avatar
Default Re: hissing sound with clitch engagement? (SOHCejcivic)
When mine was going bad it was hard to get into the gears at times.
Old Oct 5, 2006 | 02:12 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: hissing sound with clitch engagement? (92_VX_EG)
after driving through one puddle in particular, ( my wheels were almost completely underwater), I was not able to get the clutch to engage for about 20 seconds, it would just chatter around. Have any of you been able to drive a for a few months with a dieing throwout bearing, I am in school right now and can't really sacrifice the time to fix it.
Old Oct 5, 2006 | 03:21 PM
Syndacate's Avatar
I've heard an assload of descriptions of throwout bearing sounds and this is the first place I've ever heard somebody refer to it as a "hissing" sound.
I'd say it's probably the pilot bearing b4 I say it's the throwout bearing.
Old Oct 7, 2006 | 03:12 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Syndacate)
Its defintely a hissing sound
Stoich
11
Nov 6, 2007 04:30 PM
simplegreenmachine
Sep 16, 2004 07:13 PM
98GeeYes-Are
Feb 22, 2004 06:09 PM
Kserious
Feb 2, 2004 07:43 PM
bLuEciVicGuY
May 13, 2003 12:39 AM
