tell me whats wrong with my vtec......
Old Oct 4, 2006 | 07:54 PM
slo_crx's Avatar
Default tell me whats wrong with my vtec......
ok well i have tried many different things and searched for many different solutions.
here is the set up ..
fully built ls/vtec turbo. running on AEM EMS.
i have checked all the wireing and everything with a volt meter ..everything works properly.
i have swapped vtec solenoids.
i have hooked a switch to the solenoid to make sure it is opening.
i took the car to about 5k hit the switch and it opened but still no vtec./?>
my car does not have an oil pressure sending unit on the back of the block but to my understanding this is a dummy light.?,.>
my car also does not have the knock sensor hooked up >>? does AEM need this to run vtec??
i have also checked all my dowel pins and everything was there.
Old Oct 4, 2006 | 08:11 PM
Garage 808 Hatch's Avatar
is the little plug under the cam, near the dizzy, there. i had the same prob, and a machinist left a plug out
Old Oct 4, 2006 | 08:27 PM
slo_crx's Avatar
what plug are you talking about?? there is an open whole... close to the middle of the head right by the vtec solenoid.... is that supose to be pluggeD>???
Old Oct 4, 2006 | 08:31 PM
oacrep1's Avatar
Default Re: (slo_crx)
Take the dizzy off and under the cam there should be a little hole in the corner. It should be pluged with a allen key bolt i believe. I had the same problem, forgot to put it back after the rebuild and had no vtec. Good luck buddy hope that helps
Old Oct 5, 2006 | 03:59 PM
no, the one we are talking about, is under the end of the intake cam down in a little galleyway. right by the dizzy. the hole you are referring to i believe is under the middle of a cam cap, it stays open
Old Oct 5, 2006 | 07:47 PM
slo_crx's Avatar
so is there any way i cna see this "plug" by just taking off the dizzy???
Old Oct 5, 2006 | 07:53 PM
deryck324's Avatar
check the conectors on ur coolant temp , that was the problem with my friends hatch
Old Oct 5, 2006 | 08:54 PM
to see it, you atleast have to pull the valvecover
Old Oct 5, 2006 | 09:10 PM
quicksilver1689's Avatar
i ♥ snails
This shoudl be a simple problem too fix. Check the basics first 90% of the time its something simple. Vtec needs oil pressure, vehicle speed, and the motor too operating temperature. Check your AEM units settings too make sure the vtec settings didnt get messed with.
Old Oct 6, 2006 | 05:09 AM
slo_crx's Avatar
i have already checked all the basics... and yes all the electronics are working correctly.... im going to pull the valve cover today and see if i can see that plug... if not then im gonna have to wait till later this weekend when i get some spare time.
Old Oct 6, 2006 | 10:11 AM
i ♥ snails
You dont have an oil pressure sending unit? Hmmm check your AEM settings for vtec engagement.
Old Oct 6, 2006 | 11:26 AM
slo_crx's Avatar
i have the vtec oil pressure but not the one on the back of the block but i beleiv that one is a dummy light. and AEM shows that it is giving vtec the power .. i even ran a volt meter off of the ecu wiring to make sure ti was sending it and sure enoguh right at 5200 the aem gave it power. i even had a lil oil pressure drop showing that it opened the solenoid .. just no vtec crossing over>>>>????
mydb2whoopsu
Apr 1, 2014 07:39 PM
b18c1hatch1992
Feb 19, 2010 01:17 PM
javon214
Jul 8, 2008 12:52 PM
ekb16
Oct 19, 2005 11:25 PM
