engine swap??
Old May 2, 2002 | 11:27 AM
rocket_R's Avatar
Default engine swap??
would a ls motor be a direct fit into a 91 civic hatch?? if not what would need to be done????
Old May 2, 2002 | 11:32 AM
EP3_05's Avatar
Default Re: engine swap?? (rocket_R)
You will need a mount kit: Hasport, HCP, place racing, etc
shift linkage: same places or cut and weld your stock one
90-93 integra intermediate shaft and axles
rear motor mount bracket from a 90-93 integra if the motor does not come with one
b series cable transmission
Pr4 ecu
everything else should hook right up as long as you have an Si model hatch...otherwise some wiring changes will need to be made.
LSVTEC 91 Civic
Mar 3, 2005 04:17 PM
awdriscol4
17
Nov 29, 2004 04:28 AM
STHPERFORMANCE
Jan 10, 2003 04:51 PM
morter87
May 26, 2002 11:11 PM
Jeff 360
May 4, 2002 06:06 AM
