Jerky Transmission- Is transmission crapping out??
Old Oct 4, 2006 | 05:05 PM
vicdobi's Avatar
Default Jerky Transmission- Is transmission crapping out??
Hello all,
I've been having this tranmission jerk on my 97 Prelude when shifting from 1st to 2nd. It seems like when the RPM hits 3000 the tranny would want to go to
neutral before shifting up to 2nd, and when it shifts the car will
jerk. Depending on the timing of the engagement, the jerk can be both
minor and major. I'm planning on doing a transmission flush soon. It has about 80Kmiles now.
Can please somebody help? Is it a bad clutch disks? Is the transmission crapping out?
Thanks much!
Old Oct 4, 2006 | 05:21 PM
street_ride14's Avatar
Default Re: Jerky Transmission- Is transmission crapping out?? (vicdobi)
I'm assuming you're auto, just do the transmission (Honda ATF) flush and see if it gets better.
Old Oct 4, 2006 | 05:35 PM
vicdobi's Avatar
Yes its auto.
Another thing worth mentioning is that when its shifting from 1st to 2nd, there is a noticeable amount of idling..
Any other comments are really appreciated...
Old Oct 5, 2006 | 05:33 PM
gaborn73's Avatar
no cels? just b/c the engine light isnt on doesnt mean there arent any.
I have p1738 and p0700. That's 2nd gear pressure switch and Manufacturere controlled trans trouble. I bought the switch and found the wire broken upon swapping it. I spliced in a new wire and put in the new switch. I still have the codes though. Soooo I hope you check those things and come out better than me. Check the mechanics svc manual section 14 page 65 i think. good luck. do the flush and fluid change with honda fluid. maybe some lucas a/t treatment?
Old Aug 19, 2009 | 08:51 AM
Turbonetics612's Avatar
Did you ever find out what the issues was? I'm having the exact same issue with my 97 Prelude base model automatic. Please help!
Thanks.
DEZn00ts
12
Nov 6, 2015 06:46 PM
dwn2earth922
May 24, 2009 10:59 PM
v8killaz
Mar 8, 2009 07:08 AM
pinklude854
May 6, 2007 12:08 PM
