what aftermarket rods take press fit pins?
Old Oct 4, 2006 | 04:49 PM
anrkii's Avatar
Default what aftermarket rods take press fit pins?
I bought a set of eagle rods, and some stock reproduction pistons, not realizing that I would need pistons with circlips.
do any aftermarket rod manufacturers offer rods for press fitting pins?
or will I be stuck with using stock rods unless I get different pistons?
Old Oct 4, 2006 | 06:10 PM
:Josh:'s Avatar
Default Re: what aftermarket rods take press fit pins? (anrkii)
Take the pistons to a good machine shop and they can cut the necessary grooves in the pistons for you.
Old Oct 4, 2006 | 09:55 PM
anrkii's Avatar
ok, great.
so where can I purchase the piston pin circlips?
Old Oct 5, 2006 | 07:56 AM
d16dcoe45's Avatar
http://www.raceeng.com has JE spiro-locks in D or B series pin diameter--they are like $1 each. Give them a call. Just make sure you get the grooves cut in the pistons that will match the width of the spiro-locks, if that is what you intend to use. You can also use wire locks or snap rings.
lsvtec2000
Feb 6, 2009 07:08 AM
NwAmH
May 17, 2007 01:39 PM
x2gold
Jun 1, 2003 04:08 PM
KRiS1
Jul 29, 2002 01:56 PM
