turbo edit question
Old Oct 4, 2006 | 04:28 PM
zenon8890's Avatar
Default turbo edit question
hi i got a boosted OBD0 D15B vtec, i'm chipping my ecu (PM6) for my setup, but how can i find the d15b vtec map on turbo edit so i can start my tune right!?
another question, will a pm6 ecu chip work on obd1 p29?! what will happen if i did it?!
thanks
Old Oct 5, 2006 | 02:57 PM
zenon8890's Avatar
bump
Old Oct 5, 2006 | 03:08 PM
Got_soy's Avatar
Default Re: (zenon8890)
the chip should switch over from ecu to ecu, as far as the map goes you might have to go off a pm6 map and tune it
Old Oct 5, 2006 | 03:17 PM
zenon8890's Avatar
Default Re: (Got_soy)
thanks, but when i ran my stock d15b p08 on my friend's civic it was faster than my rex with the d15b pm6, i have the pm6 fuel map but i wanna start my tune right for the p08 or p28 stock maps with turbo edit, i wonder if anyone tried it before and can help!
i'm asking this cuz of the vtec engagement, pm6 doesnt have vtec and turbo edit have an option to engage the vtec through a/c switch but the problem is it just activate the vtec selenoid without changing the fuel map or ignition timing.
for example: the pr3/pw0 has low cam and high cam fuel and ingnition maps! thats the pm6 ecu doesnt have, but the p28/p08 should have same thing too (low cam/high cam)
plz if i'm wrong correct me cuz i'm confused and i read alot of info and maybe got mislead.
Old Oct 5, 2006 | 03:21 PM
Got_soy's Avatar
maybee you could try BRE its used for ODB0 B16's some people like it better than TE when it comes to vtec
Old Oct 5, 2006 | 03:28 PM
zenon8890's Avatar
thanks for ur help, is BRE software as easy as the TE?! where can i download it?!
thanks again man for ur help
Old Oct 5, 2006 | 03:33 PM
Got_soy's Avatar
http://PGMFI.ORG
they can help you out alot, maybe even with TE. just Search first before asking alot of questions
Old Oct 5, 2006 | 03:43 PM
zenon8890's Avatar
thanks again
Coutts
Engine Management and Tuning
Jul 16, 2010 12:36 AM
efjones9
Jan 8, 2009 06:44 PM
mcgee*
Jun 1, 2006 06:25 PM
zCivic
Nov 29, 2005 09:57 AM
DSRxSALSA
Jan 7, 2005 08:53 AM
