wheel shake on acceleration. Any ideas?
Old Oct 4, 2006 | 04:00 PM
EF001282's Avatar
Default wheel shake on acceleration. Any ideas?
I have a new B16 obd1 swap. just about everything has been replaced(new upper and lower balljoints, innovative front crossmember,K-sports, outer tierods and poly bushings and also got an alignment, the shake occurs only on take off from a dead stop or rolling start and only on the driver side, I had all four wheels rebalanced and it still happens . I also have rota GT3's, maybe I need centering rings? The shake doesnt happen when I am coasting or hitting the brakes, only on 1st and sometimes 2nd, mild to hard acceleration. Could it be defective rebuilt axle? I am lost any ideas?
Old Oct 4, 2006 | 04:21 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: wheel shake on acceleration. Any ideas? (EF001282)
I would say axel, but just in case I would try a friends set of wheels on the front and see if that fixes it.
Try some centering rings for sure.
Old Oct 4, 2006 | 04:40 PM
shythappenz's Avatar
wheel bearing
Old Oct 4, 2006 | 05:00 PM
Crx Jimmy's Avatar
had the same problem with a brand new axle the axle was just bad or balanced incorrectly
Old Oct 4, 2006 | 05:36 PM
EL Vap133's Avatar
Are your lug nuts on tight?
9honda5civic
Mar 22, 2020 09:57 PM
method520
Mar 15, 2010 09:08 AM
beanbag
Dec 7, 2008 09:30 PM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
Chicano
11
Jan 19, 2005 08:14 PM
