Oil Pressure Issue...HELP A MAN OUT
Old Oct 4, 2006 | 02:41 PM
SlowSOHC-T's Avatar
Default Oil Pressure Issue...HELP A MAN OUT
So today I finally got the line for my oil sending unit for my electrical oil pressure gauge. So I hook the line up to my oil feed adapter and run it to the sending unit. Go to start the car and check for leaks. I noticed as soon as I turned the key over it pegged 100psi. So Im thinking well I got the wires backwards. So I pull out the gauge and check and all the wires are fine..
(if looking at the back of the gauge) Top is Sending unit, Left is 12v, and right is ground. So than I look at the line and see no leaks or anything. Anyone have any idea? Im going to go out and re-wire the gauge and see if I have a open line or anything...
Someone help a man out here...
Old Oct 5, 2006 | 06:35 AM
SlowSOHC-T's Avatar
Nobody?
Old Oct 5, 2006 | 11:02 AM
SlowSOHC-T's Avatar
No one...Not even a good luck..LOL
Old Oct 5, 2006 | 11:59 AM
k00lt1nt's Avatar
Default Re: Oil Pressure Issue...HELP A MAN OUT (IWANTAHB)
i would say get the manual...I prefer the manual gauges that give you an acurate reading of your motor. The eletrical gauge you never know what would happen and you might get short and be sending you the wrong info.. thats just my preference though... but to get back on subject.. i have no idea!! hahahah.sorry pla..GOOD LUCk!!!
Old Oct 5, 2006 | 03:04 PM
SlowSOHC-T's Avatar
Default Re: Oil Pressure Issue...HELP A MAN OUT (k00lt1nt)
ITS FIXED...Thanks though ......
Old Oct 12, 2006 | 01:17 PM
elusive123's Avatar
you had it wired wrong right ?
Old Oct 13, 2006 | 03:43 AM
SlowSOHC-T's Avatar
Default Re: Oil Pressure Issue...HELP A MAN OUT (elusive123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elusive123 &raquo;</TD></TR><TR><TD CLASS="quote">you had it wired wrong right ?
Nope...
Old Oct 13, 2006 | 07:12 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB &raquo;</TD></TR><TR><TD CLASS="quote">ITS FIXED...Thanks though ...... </TD></TR></TABLE>
So what was the problem?
Old Oct 13, 2006 | 11:54 AM
SlowSOHC-T's Avatar
Default Re: Oil Pressure Issue...HELP A MAN OUT (Chiovnidca)
The oil sending unit wire going to the guage itself was loose. Turned it about a 1/4 turn and boom everything started working...
HXMan
Oct 19, 2012 07:00 AM
95LStizzy
Mar 12, 2006 12:35 PM
TurboSI24
Sep 27, 2005 02:18 AM
Vtak
Apr 29, 2005 11:24 AM
SRd240sx
Nov 22, 2004 06:43 PM
