front lower ball joint help please.
ok i just put my new axle in and im in the process of tightening the castlenut onto the ball joint bolt but the bolt spins with the nut and it wont tighten, how do you guys keep that bolt from spinning? thanks in advance.
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
put your jack under the control arm and put some pressure on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">put your jack under the control arm and put some pressure on it.
</TD></TR></TABLE> i tried that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! »</TD></TR><TR><TD CLASS="quote"> i tried that
well, try again. make sure the castle nut is not cross threaded, or that the threads on the ball joint are not boogered up.
</TD></TR></TABLE>well, try again. make sure the castle nut is not cross threaded, or that the threads on the ball joint are not boogered up.
93(Civic)EG6
Sep 1, 2007 08:06 PM
EX-JAY
Oct 25, 2004 02:46 PM
