What kinda wire crimpers are you guys using?
Old Oct 4, 2006 | 11:56 AM
Race Egr's Avatar
Default What kinda wire crimpers are you guys using?
Just curious what kind wire crimpers you guys are using for ring terminals, butt connectors, etcc. Im lookin for some good quality ones
Old Oct 4, 2006 | 03:34 PM
F20Cteg's Avatar
Default Re: What kinda wire crimpers are you guys using? (NAPIER)
I don't. I solder and use heat shrink.
Old Oct 4, 2006 | 03:56 PM
Howitt's Avatar
Default Re: What kinda wire crimpers are you guys using? (F20Cteg)
the ones with the blue handle that cost $25 a pair since I loose them atleast once a year
Old Oct 4, 2006 | 04:24 PM
rlockwood's Avatar
vice grips for small connectors, kurt vice for 8ga or larger, never had a failed connection
Old Oct 4, 2006 | 05:05 PM
skyman88's Avatar
Default Re: What kinda wire crimpers are you guys using? (rlockwood)
For simple butt connectors I use these:
http://www.mytoolstore.com/klein/1005.html
I've had them now for about 4 years, they work 10x better than the crappy Autozone ones I had before.
~SKY~
Old Oct 4, 2006 | 06:20 PM
TurboLSVtecTeg's Avatar
Default Re: What kinda wire crimpers are you guys using? (skyman88)
I use the AMP Tyco Electronics Hand Crimper. The Frame is about $75 and the die sets can range anywhere from $50 to $700. I think the die set for non-insulated connectors was like $50-75.
Ok ive got updated info for ya. You can get these crimpers on http://www.alliedelec.com . The AMP Pro Crimper II Frame Set is $66.00 Allied Stk#527-0108. The Die set I use for uninsulated connectors is $94.50 Allied Stk#527-0187. It will work with wire ranging from 22-10awg. Any other questions feel free to PM me.
Modified by TurboLSVtecTeg at 10:34 PM 10/4/2006
Old Oct 4, 2006 | 10:37 PM
40oz's Avatar
Oh hell.
Like the guy above, I often use the AMP Solistrand terminals. These are un-insulated, so you have to heat shrink over them. This can suck if you're tired and crimp the damn connection before putting the heat shrink on the wire. The plus side, though, is that they aren't as thick as pre-insulated options, if you plan on heat shrinking the length of a bundle. If you're splicing multiple wires in the same bundle, stagger the splices so you don't end up with a big bulge.
I bought my AMP Pro Crimper II from Digi-key. Here are AMP part numbers and prices at Digi-key (www.digikey.com):
AMP 58546-1 - $118.50 <-- includes the 22-10 awg un-insulated terminal die set
AMP 31818 - $0.199 min. qty. of 10 <-- 22-16 awg butt splice
AMP 31819 - $0.216 min. qty. of 10 <-- 16-14 awg butt splice
AMP 32151 - $0.288 min. qty. of 10 <-- 12-10 awg butt splice
I'm pretty sure you can get the splices cheaper at other places; I think I bought my last bunch from Mouser (www.mouser.com).
AMP also has Solistrand un-insulated ring terminals, disconnects, etc. Unfortunately, their website is a big piece of ****, and you actually have to concentrate pretty hard just to find a freaking part number so you can try to order the crap somewhere.
There are two options for quality pre-insulated splices/terminals, Molex and Raychem (owned by AMP). The Raychem DuraSeal line and Molex Perma-Seal line are probably nearly identical in quality, the only difference being Raychem costs twice as much and the stupid *** crimp tool is impossible to find and much more expensive. The crimper appears to be the same style as the Molex though, so I imagine you could interchange them.
Item numbers for Molex from Waytek (www.waytekwire.com):
479 Perma-Seal crimp tool - $30.60
30980 - $0.2096 min. qty. of 24 <-- Perma-Seal butt splice - 20/18 awg
31980 - $0.2273 min. qty. of 22 <-- Perma-Seal butt splice - 16/14 awg
32980 - $0.2835 min. qty. of 18 <-- Perma-Seal butt splice - 12/10 awg
I guess I'm a little crazy about my wiring.
Old Oct 5, 2006 | 05:17 AM
2point2's Avatar
vice grips!!
....but i dont think i have any crimp connectors on my CRX, even with the massive amount of custom wiring.
Old Oct 6, 2006 | 08:23 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">I don't. I solder and use heat shrink.
&gt;&gt;&gt;&lt;&lt;&lt;</TD></TR></TABLE>
ditto.
we have some of those amp crimpers here at work and they are the business, but I'm not spending that for a pair for personal use when solder works just as well IMHO. The stuff we do at work is tiny, so they are totally worth the money here, most everything is 26ga or smaller.
Old Oct 6, 2006 | 10:35 AM
timg's Avatar
I use one like this. It's MUCH more robust and makes MUCH better connections that the cheap ones you can find in most auto parts/hardware stores.
http://www.partsexpress.com/pe...0-642
Tim
Old Oct 9, 2006 | 05:01 PM
turboekcivic's Avatar
Default Re: (timg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">the ones with the blue handle that cost $25 a pair since I loose them atleast once a year</TD></TR></TABLE>
yup the ones you can buy from homedepot
Old Oct 9, 2006 | 06:45 PM
AspectIndustries's Avatar
Up for some infos.
Im interested in knowing a little or two about good and bad crimps, for what conditions etc.
Old Oct 9, 2006 | 07:25 PM
SpeedDreamz.com's Avatar
Default Re: What kinda wire crimpers are you guys using? (synik)
BLue Point
Old Oct 10, 2006 | 01:39 PM
Default Re: What kinda wire crimpers are you guys using? (SpeedDreamz.com)
my friend bought the mac one and we compared it to the blue one from homedepot same exact thing but 20 dollars more
Old Oct 13, 2006 | 11:26 PM
turbosi03's Avatar
Default Re: What kinda wire crimpers are you guys using? (turboekcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboekcivic &raquo;</TD></TR><TR><TD CLASS="quote">
yup the ones you can buy from homedepot </TD></TR></TABLE>
Yep... Out of all the audio installs I've done since 14yrs old, I find these to be the quickest, easiest to use (lots of leverage).
Old Oct 16, 2006 | 09:32 PM
AZSTATEPOLICE's Avatar
Default Re: What kinda wire crimpers are you guys using? (turbosi03)
Because OEM Honda pins are the only way to go!!!
Old Oct 17, 2006 | 07:15 AM
gldndrgn14's Avatar
Default Re: What kinda wire crimpers are you guys using? (AZSTATEPOLICE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZSTATEPOLICE &raquo;</TD></TR><TR><TD CLASS="quote">Because OEM Honda pins are the only way to go!!!
i second that. but where do you get the male and female pins for the plugs from? i can source terminal splices but not the male and female plug pins.
Old Oct 17, 2006 | 12:42 PM
locash's Avatar
Default Re: What kinda wire crimpers are you guys using? (gldndrgn14)
Hasport gets most of the pins direct from the manufacturer, in 5000 piece reels. To be honest, that crimper is not anywhere near as nice as the OEM machine, but it works pretty well for about a 1000 crimps, then its time to replace it.
Old Oct 18, 2006 | 04:10 AM
gldndrgn14's Avatar
Default Re: What kinda wire crimpers are you guys using? (locash)
do you think hasport could sell me some?
Old Oct 18, 2006 | 07:10 AM
vaporboy12's Avatar
the oem honda crimper is money i stole one when i left my dealer
Old Oct 18, 2006 | 10:26 AM
rip94delsol's Avatar
Default Re: What kinda wire crimpers are you guys using? (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">the oem honda crimper is money i stole one when i left my dealer </TD></TR></TABLE>
thief!!! then all the other techs get blamed and a huge meeting for some crimpers.. it happens all the time.
Old Oct 18, 2006 | 04:36 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 &raquo;</TD></TR><TR><TD CLASS="quote">do you think hasport could sell me some?</TD></TR></TABLE>
It's like $35 for 5000 pins from Sager or Newark.
Old Oct 21, 2006 | 04:58 PM
eg underclassman's Avatar
Default Re: What kinda wire crimpers are you guys using? (nfn15037)
I use snap-on they have a good pair for about 35-40 bucks. I've had mine for about two years.
Old Oct 23, 2006 | 04:26 AM
gldndrgn14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
It's like $35 for 5000 pins from Sager or Newark.</TD></TR></TABLE>
any idea what those plug pins are called? i wouldnt know where to search in their online catalog. haha i know it would be under connectors.
edit**
found some plugs, but dont know if the pins come with them.
http://www.newark.com/NewarkWe...00100
Old Oct 24, 2006 | 12:35 AM
sympatico's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboekcivic &raquo;</TD></TR><TR><TD CLASS="quote">my friend bought the mac one and we compared it to the blue one from homedepot same exact thing but 20 dollars more </TD></TR></TABLE>
accord95vtec
Audio / Security / Video
Jan 10, 2009 07:05 AM
lee0149
Nov 20, 2008 07:49 AM
5lugSlug
Oct 12, 2005 05:35 AM
tub_sephiroth
Mar 27, 2004 09:07 AM
Traction
Jan 21, 2004 03:23 PM
