rear drum to disc brake swap for 95 civic
Old Oct 4, 2006 | 10:56 AM
fwlan's Avatar
Default rear drum to disc brake swap for 95 civic
I searched for a post on rear brake swaps but didn't find much. Can anyone tell me exactly what I need to pull off of the donor car in order to do the swap? Is it a direct bolt-on swap from civic to civic or will I need to modify anything? I won't actually have access to the donor cars so I need to tell the guy what to pull. Also, is there a benefit to getting integra brakes or are they pretty much the same?
Old Oct 4, 2006 | 11:33 AM
Chem Geek's Avatar
Default Re: rear drum to disc brake swap for 95 civic (fwlan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwlan &raquo;</TD></TR><TR><TD CLASS="quote">I searched for a post on rear brake swaps but didn't find much. </TD></TR></TABLE>
Then you certainly didn't search very hard, there's a post at the top of this forum that says FAQ(s). It has at least three or four threads on brake swaps.
You need: trailing arms, e-brake cables, calipers, rotors, pads, lines. It's easiest if you just take the trailing arm and everything attached to it. From there you could also do the 4040 proportioning valve and a larger master cylinder. Might as well get it all from an Integra. All Integra's (94-01) except for the Type-R have the same size brakes.
Old Oct 4, 2006 | 06:32 PM
thahuhstunna's Avatar
https://honda-tech.com/zerothread?id=641639
https://honda-tech.com/zerothread?id=820484 https://honda-tech.com/zerothread?id=812062
try searching the faq's next time, these should get you started. laziness doesn't fly here.
jdblock
Northern California (Sales)
Feb 1, 2018 12:03 PM
AnotherEJ
Jun 22, 2010 06:02 AM
jagumbel
Jun 15, 2009 10:29 AM
doubleshotz
Oct 12, 2007 03:46 PM
qat727
Dec 14, 2006 07:59 PM
