2.0 gsr question
Old Oct 4, 2006 | 10:46 AM
conceptEG's Avatar
Default 2.0 gsr question
gentleman..
hello.. i was looking for an opinion to see what you all think.. i have a gsr in my eg/si im smoking in the higher rpm's.. so i checked out the valve seals.. their fine.. anyway its got to be the piston and rings..
i was wondering what kind of hp difference a sleeved 2.0 would be over a stock 1.8? im going to stay at the stock c.r due to having a jrsc.. im looking for around 250-275hp.. im using a crv crank pulley and a neptune program for the set up..walbro 255 fuel pump..what injectors would you suggest?
laskey has an econo build for 2400.. new everything but sleeves.. its cheaper then the 3500 i will pay for the sleeved gsr from inline.. i have aprox 4k to spend.. opinions please!!!!!!!
thanks fellas..
by the way.. hit a deer on the gsxr last night around 40mph and didnt lay it down.. my knee is so swollen.. i think i took an antler to the cap. then the deer swung around missing my junk by a mere inch if that... thank god for cold nights..lololol
Old Oct 4, 2006 | 10:56 AM
kevmugen's Avatar
Default Re: 2.0 gsr question (hatr-aid)
with the 2.0 you would have more low end torque and mid-range power,
not sure but about the H.P. think it would be the same...
Reaperbuilt
Engine Machining & Assembly
Jun 26, 2018 01:12 PM
darklyte
Nov 11, 2009 09:00 AM
conceptEG
Sep 18, 2006 06:08 PM
integrated civic
Mar 2, 2003 07:51 PM
11secdx
Jan 16, 2002 08:47 AM
