D15 Bogging
well this morning my car started just fine when i dropped my brother off.then a few hours later i went to go start her up again idle was jumping between 1-2 and it felt like it was going to die on me.when i drive it starts to bog and it does this in all gears.can you guyz please help what would be wrong. im already planning to do a motor swap. i just need her to work for now cause its the only car we have rite now.
Bogging.....when my car just recently bogged it only happened when I was at a low RPM and that was because of my Distributor cap that had gotten moisture under the cap, I took it off and found that there was water in there... also it had rust accrual on the contacts, So I just bought another rotor and cap; idle surge could mean either you have a vaccuum leak or you have a bad eacv...Are you getting any codes?
nope no codes.it just started doing it too.before it was fine then a few hours later i went to go start her up and thats when the problem started.And i dont think there would be water in the distributor because he hasnt been raining for a while.And also the tone of my engine doesnt sound the same anymore if that helps.
Modified by xlusiveracer at 4:13 PM 10/4/2006
Koko4
Oct 8, 2014 09:37 PM
msinsky14
Sep 11, 2006 11:37 PM
