obd0/obd1 ecu socket/chippers...i have a quick question...dr disco
Old Oct 4, 2006 | 10:22 AM
xDicktonesx's Avatar
Default obd0/obd1 ecu socket/chippers...i have a quick question...dr disco
i stumbled across a box of chips and i think they are compatible with these ecus but i want to make sure. they read as follows:
part number M27C64A
-15F1
B880A
0148L
singapore
they are 28 pin and look exactly like the zif chips we all use. thanks.
Old Oct 4, 2006 | 10:50 AM
CRX Toad's Avatar
Default Re: obd0/obd1 ecu socket/chippers...i have a quick question...dr disco (xDEFTONESx)
DrDisco sucks.
Old Oct 4, 2006 | 10:54 AM
drdisco69's Avatar
The 64 in the part number stands for 64kb, which is the capacity of the chip. This is too small to store the rom, which is 32kB, which is equal to 256kb. Therefore, you need a chip of at least 256kb capacity, a 512kb will also work. The other important piece of info is the -15F1. The 15 indicates 150ns response of the chip. To work reliably, the chips must be 200ns or faster, which is indicated by a -20 or lower.
CRX Toad sucks better.
Modified by drdisco69 at 3:06 PM 10/4/2006
Old Oct 4, 2006 | 11:23 AM
Default Re: obd0/obd1 ecu socket/chippers...i have a quick question...dr disco (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The 64 in the part number stands for 64kb, which is the capacity of the chip. This is too small to store the rom, which is 32kB, which is equal to 256kb. Therefore, you need a chip of at least 256kb capacity, a 512kb will also work. The other important piece of info is the -15F1. The 15 indicates 150ns response of the chip. To work reliably, the chips must be 200ns or faster, which is indicated by a -20 or lower.
Modified by drdisco69 at 3:06 PM 10/4/2006</TD></TR></TABLE>
cool thanks. im in the military and i can order the right ones by the hundreds anyway. knowing that, i can look up the one i need.
Old Oct 4, 2006 | 11:26 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: obd0/obd1 ecu socket/chippers...i have a quick question...dr disco (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">DrDisco sucks. </TD></TR></TABLE>
PMs him
And him
Only the first part of dr discos post I can back with my own info but he knows his stuff and I would trust him on the rest
93supercoupe
Apr 27, 2007 06:02 PM
xDicktonesx
Oct 4, 2006 12:24 PM
Kwuaymaikrup
Apr 1, 2004 08:11 PM
93solsigsr
Apr 25, 2003 07:08 PM
