tranny problem please help!!
alright im having a problem with my tranny. i have a 98 civic ex coupe with the stock d16y8 in it. well when i drive it sometimes pops out of gear when im going n when i just first put it in as well. Its only doing it in 2nd gear. could it be a loose shift linkage or bad syncros. any comments would help.
Sounds like your synchros are going out. First thing to do if you have a short shifter is to get rid of it.
If not, try getting GM Synchromesh, Friction Modified. You can buy those at any General Motors/Chevy dealership. Works great with Honda transmissions.
its your syncros because they match up your transmission speed with your engine speed so you dont grind your ******* gear teeth off when you try to shift so you need to get them fixed, but that will be more trouble and money than its worth and you'll end up spending just as much at a shop for them to fix it, so just buy a new tranny it will save you time and money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by your_moms_fat_ass »</TD></TR><TR><TD CLASS="quote">its your syncros because they match up your transmission speed with your engine speed so you dont grind your ******* gear teeth off when you try to shift so you need to get them fixed, but that will be more trouble and money than its worth and you'll end up spending just as much at a shop for them to fix it, so just buy a new tranny it will save you time and money </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Sounds like your synchros are going out. First thing to do if you have a short shifter is to get rid of it.
If not, try getting GM Synchromesh, Friction Modified. You can buy those at any General Motors/Chevy dealership. Works great with Honda transmissions. </TD></TR></TABLE>
did you two actually even read what he said????? he never mentioned grinding gears, popping out of gear has nothing to do w/ the synchros.
OP: first things to check, shift linkage and all associated bushing for wear, looseness, etc.... then check motor mounts.
thanks for the input guys umm ya i think it might be the shift linkage bc a local shop installed the secondary o2 sensor n used a torch i think to get the exhaust out of the way so it might be the linkage ill check that then
I hate to say it, but it's probably worse than that. If it's popping out of gear, there is probably an internal component with excessive wear somewhere between the shift arm and 1/2 shift fork. Could be a worn out interlock.
i' having problem shifting from 4th to 5th... it's not smooth & i get this grinding sensation on the stick... is it the synchros or the linkage? i'm gonna open up my tranny tomorrow night to see what's going on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic »</TD></TR><TR><TD CLASS="quote">had the same problem, ended up being a broken shift fork
i think it was like 90 from honda</TD></TR></TABLE>
bout time somebody spoke the truth.
i think it was like 90 from honda</TD></TR></TABLE>bout time somebody spoke the truth.
Well a bent shift fork would give you those symptoms, but it would have to be bend upward for the shifter to pop out of gear. And since first and second gear share the same shift fork, you'd be experiencing problems with first gear as well.
The shift shaft rotates the interlock which moves the rods up and down. I'm still thinking there is a problem with the interlock (they wear out) which is causing the shift fork to disengage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_eg »</TD></TR><TR><TD CLASS="quote">thanks for the input guys umm ya i think it might be the shift linkage bc a local shop installed the secondary o2 sensor n used a torch i think to get the exhaust out of the way so it might be the linkage ill check that then</TD></TR></TABLE>
If it is the linkage how long have you been driving it like that ?
it might already be damaged?
From what i seen if it keeps poping out of gear its either your shift fork fingers are dramitcaly worn or the gear selector teeth are worn down. When the gear selector wear happens you should have been grinding gears for a long time already.
i have been driving with it for about a week. it never grinded 2nd before. but now when i put it in second pops n there is a slight grind. an when im crusing in second it will just pop out of second and you can hear grind alil as welll
if it was the linkage you would have some sort of problem with more then 1 gear.
I recomend you do check the linkage first. Replace your fluid with syncromesh, maybe. There is the posibilty the linkage was damaged some how and damaged your tranny. Or you can buy my Y8 tranny (shamless plug)
good luck with your tranny man.
allmotorEG-SI
Apr 2, 2005 08:02 PM
