HELP: clutch pedal pressure and idle problem
Old Oct 4, 2006 | 08:57 AM
ge_itr's Avatar
Default HELP: clutch pedal pressure and idle problem
i have a 94 prelude vtec. my clutch pedal pressure keeps dropping especially when i go on the highway. if i go for a long time, my pedal will fall all the way to the floor. i have to use my toe to get it back up and pump it until there's some pressure again. but this cycle repeats. i just replaced my master cylinder(rebuilt) bout a month ago and clutch slave cylinder about a year ago. i did notice shortage of brake fluid but continues after refill. this just started happening. the brakes are fine.
i replaced my fuel filter and add fuel injector cleaners but my car still runs weaker than usual sometimes. and sometimes when i get a light/stop sign and go to neutral, my rpm will drop and bounce back and forth for about 5sec. sometimes it will go too low and stall(in neutral), so i have to give it a little rev. this happened about a month ago.
does anyone knows how to fix these problems?
Old Oct 4, 2006 | 09:30 AM
mgags7's Avatar
Default Re: HELP: clutch pedal pressure and idle problem (ge_itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote"> replaced my master cylinder(rebuilt)</TD></TR></TABLE>
there is problem #1, NEVER use rebuilt master/slave cylinders....buy a new one
does anyone knows how to fix these problems?</TD></TR></TABLE>
clean out your throttle body and the IACV, then use the posted "FITV idle bouce fix" or something like that, a quick search should turn it up, just re-tighten the plastic screw on the back of the FITV
Rickcrx
Transmission & Drivetrain
Apr 5, 2010 02:08 PM
Rickcrx
Mar 11, 2010 04:30 PM
IgnitionZ05
Dec 8, 2006 11:27 PM
ge_itr
Oct 5, 2006 01:24 PM
yellowturbo
Feb 7, 2005 09:18 AM
