97 EX Rear Cat O2 sensor ?
Old Oct 4, 2006 | 08:42 AM
alotawatts's Avatar
Default 97 EX Rear Cat O2 sensor ?
97 EX Civic stock D16Y8 / automatic
Is the rear Cat O2 sensor the same part # as the front/manifold O2sensor ?
thx
Old Oct 4, 2006 | 09:13 AM
poison's Avatar
Default Re: 97 EX Rear Cat O2 sensor ? (alotawatts)
No. They are not the same O2 sensor.
Old Oct 4, 2006 | 09:22 AM
sicones's Avatar
Default Re: 97 EX Rear Cat O2 sensor ? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">No. They are not the same O2 sensor. </TD></TR></TABLE>
They are the same "sensors" the only difference is the rubber grommet on the one after the cat, and the 99-00 have the male/female connectors switched
36531-P2R-A01 SENSOR, FR. OXYGEN 1 1997 CIVIC 160.76
36532-P2R-A01 SENSOR, RR. OXYGEN 1 1997 CIVIC 190.63
Old Oct 4, 2006 | 09:53 AM
alotawatts's Avatar
Default Denso -
Here is a Denso part number list for my car but they all indicate without Vtec ?
I did the list selection with D16Y8 ??
Confused
O2 Sensors
Regular Class Universal O2 sensor 234-4209 234-4209 FRONT; w/o V Tech Engine; $45.92
Regular Class Universal O2 sensor 234-4209 234-4209 REAR; Automatic Transmission w/o V Tech Engine; $45.92
Regular Class Universal O2 sensor 234-4209 234-4209 REAR; w/o V Tech Engine; $45.92
Super Class OE identical O2 sensor 234-4099 234-4099 FRONT; w/o V Tech Engine; $58.73
Super Class OE identical O2 sensor 234-4096 234-4096 REAR; Automatic Transmission w/o V Tech Engine; $87.95
Super Class OE identical O2 sensor 234-4065 234-4065 REAR; w/o V Tech Engine; $84.82
Modified by alotawatts at 12:52 PM 10/4/2006
Old Oct 4, 2006 | 10:07 AM
sicones's Avatar
Default Re: Denso - (alotawatts)
just get a universal DENSO 4 wire o2 sensor off ebay for $50, it comes with connectors and some comprehensive instructions, you have to be a retard to expletive it up
the universal is 234-4209
I just look at the DENSO website they mean without VTEC as in not DOHC
Old Oct 4, 2006 | 11:57 AM
alotawatts's Avatar
Default Re: Denso - (sicones)
Uhhh
Mine is an overhead cam Vtec. That's why I'm asking -They don't list any for VTEC .
Why ? There is'nt anything Honda-Vtec-proprietary about the downstream sensor is there ?
Old Oct 4, 2006 | 12:06 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts &raquo;</TD></TR><TR><TD CLASS="quote">Uhhh
Right, but yours is a SOHC, not DOHC.
Old Oct 4, 2006 | 12:10 PM
philosofy1's Avatar
ngk has o2 sensors on this site, check it out.
http://www.sparkplugs.com/default.asp
also, why not just go to the local parts store and pick up the exact one you need.
forget using those universal ones. you have to cut the oem harness off to get it to work. if your like me, i try to keep everything oem looking as possible.
Old Oct 4, 2006 | 12:13 PM
Mr Hammond's Avatar
a/k/a Jomo
Just for the record it says "w/o V Tech Engine".
Old Oct 4, 2006 | 12:36 PM
sicones's Avatar
Default Re: Denso - (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">Just for the record it says "w/o V Tech Engine".</TD></TR></TABLE>
enough reason alone not to believe that website
OK! I did the research for you.....you need Part Number: 234-4659 EX L4/1.6 GAS - FI REAR
Old Oct 4, 2006 | 04:05 PM
alotawatts's Avatar
Thanks sicones
I've had problems with universals....................
Crosstour1
Mar 15, 2015 02:47 AM
CivicExMaster
25
Oct 15, 2008 07:16 PM
silentblackhat
Feb 15, 2005 10:33 AM
ldodol
Mar 29, 2003 01:24 PM
DestinLnGa
Sep 23, 2002 08:47 AM
