1993 Accord SE Violent Shaking in Reverse
Old Oct 4, 2006 | 06:44 AM
CBL9's Avatar
Default 1993 Accord SE Violent Shaking in Reverse
When you shift into reverse there is a violent shaking with your foot on the brake. Anyone know what is causing this, I can presume it is tranny related. Any similiar experiences?
Old Oct 4, 2006 | 08:09 AM
Stealthman80's Avatar
Default Re: 1993 Accord SE Violent Shaking in Reverse (CBL9)
only in the pedal or is it the whole car? caus if its teh whole car its most likely the front torque rod
Old Oct 4, 2006 | 10:59 AM
CBL9's Avatar
Default Re: 1993 Accord SE Violent Shaking in Reverse (Stealthman80)
It is in the entire car. From the steering wheel to the seats. What is the front torque rod? Never heard of such a part. Hopefully it is not embedded within the tranny somewhere
OR
Is this an external part like a transmission mount that connects from the tranny to the chasis?
Old Oct 4, 2006 | 11:02 AM
Ross 2.0's Avatar
In a Junkyard near you.
I would bet the rear tranny mount is broken. This will cause the vibration you are speaking of.
Old Oct 4, 2006 | 02:30 PM
Default Re: (MooGoCow3)
you see that big dogbone looking mount right in front of the rad thats the front torque rod. vibration is either front or back mount I changed my front and it eliminated about 80% of the vibration
Old Oct 4, 2006 | 03:18 PM
CBL9's Avatar
Default Re: (Stealthman80)
I looked at the front mount a few minutes ago actually it looks pretty solid. What sort of if any play should I see from it? It felt pretty sturdy etc. Not loose or anything like that. I do not know much about worn mounts from motor to transmission, never had a problem with any car I have ever owned. Until now I guess
Old Oct 5, 2006 | 09:13 AM
X-Crement's Avatar
Default Re: (CBL9)
What types of mods do you guys have that you are bending the torque rod?
Old Oct 5, 2006 | 09:23 AM
Default Re: (X-Crement)
uhh they dont bend the rubber insdie wears out, if th efront one looks ok then its the rear one the rear ones kinda expensive
funtak
Mar 1, 2008 11:38 AM
wernhersey
Mar 16, 2006 10:14 AM
mr_ek9
Jan 30, 2006 02:33 PM
