Stock Motor or Swap.......
I got the 02 EX and im debateing what to do with my motor. I was just wondering if its worth just modding out the single cam or just going for a swap. I was just wondering how fast people got the stock motor. Cause alot of people say its slow but i keep up to alot of cars like DOHCs and stuff. Just need some advice
<FONT COLOR="red"><U>Search</FONT></U> is your best friend partner. There are a million threads here about engine swaps.
Plus we have an FAQ section just for questions like yours.
if you build your engine right you can get alot of hp with turbo"i did the turbo route and the hole 9 yards" but i dont now about na seems it would be hard. one guy was right it will cost alot of money but the swaps cost alot of money to around $10,000 if you pay some one. you can get more hp for your money with turbo and built motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 518jacob »</TD></TR><TR><TD CLASS="quote">if you build your engine right you can get alot of hp with turbo"i did the turbo route and the hole 9 yards" </TD></TR></TABLE>
On a D17A2? I'm calling BS until I see a dyno sheet or a mod list and a dyno sheet.
There is no way ANYBODY would classify the output of a D17A2/1 as "alot". It's just not possible. Now, if you are talking about a boosted K series, then you would be right. You can extract alot of power out of those things with the right parts and someone that knows how to tune the thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 518jacob »</TD></TR><TR><TD CLASS="quote">ok i have 310 hp on race gas 20 psi and 30 shot </TD></TR></TABLE>
Then you really suck at tuning.
What octane gas is that you are using?
What nitrous kit you use?
Turbo setup?
Fuel system?
Ignition system?
Engine management?
Pics?
What octane gas is that you are using?What nitrous kit you use?
Turbo setup?
Fuel system?
Ignition system?
Engine management?
Pics?
you turbo'd your car and its never been on the dyno? im callin BS. pull up a mod sheet for us while your at it. and also for red.em2, if your making 300whp+ from a 100-115whp motor, thats 3x's its power figures so i think its pretty impressive. thats like making 600+whp on a k20a
but hey, to each his own.
How did you tune the EMS with no dyno time?
This reeks of MAJOR......
Get your head out of your ***, and come talk to us... In the meantime, quit hijacking the OP's thread. Make your own if you want to prove or disprove that you have a 300 whp d17a2 that has never seen a dyno.
show some pics, or a dyno sheet or even talk about ur engine like u know what ur talking about.
99.9999% of people running 310whp, when they list their engine parts list a lot more than
Turbo
Nitrous
310 WHP
VteCKFluiDByMoTuL
Turbo
Nitrous
310 WHP
VteCKFluiDByMoTuL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiauna »</TD></TR><TR><TD CLASS="quote">well couldnt u build it then throw a turbo on it or is that not worth it</TD></TR></TABLE>
You could, but an N/A build uses High C/R pistions while a Turbo uses low. So it would be pointless to build it before u boost it.
parts list i got the block heat treaded, forged internals, pistons were custom built low compression, crank bal, drilled block for head bolts, head was bluit by P&P turbo cam, 3 degree valve job, port and polish, bigger valves, springs, 73mm throttle body, flywheel 8 lb, racing clutch, under drive pulley alternater power steer, t3/t4 turbo, oil cooler, apexi boost controller, vtec controller, AEM ems, gas cell in truck with battery octane 110, nitrous cooled intercooler, custom charged piping that i did, radiator 30% increase in flow, no ac, the nitrous is direct port nos part #3008 got different jets for it. This is the basic stuff that i could think of in 2 seconds. beside little stuff high temp radiator hose, short shift kit, gauges ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 518jacob »</TD></TR><TR><TD CLASS="quote">parts list i got the block heat treaded, forged internals, pistons were custom built low compression, crank bal, drilled block for head bolts, head was bluit by P&P turbo cam, 3 degree valve job, port and polish, bigger valves, springs, 73mm throttle body, flywheel 8 lb, racing clutch, under drive pulley alternater power steer, t3/t4 turbo, oil cooler, apexi boost controller, vtec controller, AEM ems, gas cell in truck with battery octane 110, nitrous cooled intercooler, custom charged piping that i did, radiator 30% increase in flow, no ac, the nitrous is direct port nos part #3008 got different jets for it. This is the basic stuff that i could think of in 2 seconds. beside little stuff high temp radiator hose, short shift kit, gauges ...</TD></TR></TABLE>
it's cool that you're taking your time to answer everyones doubts but you need to backup your claims. if you say you have this and that, but if you can't back it up, these are the types of responses you are going to get.
as far as i know, there's only one person who has successfully reached ~300whp on their D17, and if he didn't post pics, he'd be getting the same responses as you. he's posted tons of pictures of his setup, even his progress, and to top it off, a dynosheet.
you said you had your engine built by DH Racing? you must've been really lucky then, because from what i've heard- they're out of business, they've scammed a lot of people, and to top it off, whatever work they completed was crap.
back to the topic for jsut a moment,
D17 isnt bad for a turbo but its a ton of work and it still wont be really fast. Swap is awesome but a good engine will cost you. one nice part about a d17 is that you can buy a whole engine for like $600 so if it dies, your not out a ton of cash.
I'd like to see that 310 hp car in person but sadley I live accross the country from you. How about some pics? maybe even a video clip, youtube is pretty easy to set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thecheat »</TD></TR><TR><TD CLASS="quote">I'd like to see that 310 hp car in person but sadley I live accross the country from you. How about some pics? maybe even a video clip, youtube is pretty easy to set up.</TD></TR></TABLE>
The only PROVEN 300+ whp D17 EM2 Civic, https://honda-tech.com/zerothread/1772982.
khmrdreamieboix
13
Jan 29, 2007 07:01 AM
