please help me wire up my amp and sub
Old Oct 4, 2006 | 12:32 AM
riceball777's Avatar
Default please help me wire up my amp and sub
i will let the head unit power the speakers. i will just use the amp to power the sub. the head unit has 3 sets of rca's. 2 normal sets and one that says sub out. the amp is a 2 channel amp with 2 sets of rca's.
How do i run the rca's???
right now i'm running only one set of rca's from the head unit to the amp. i'm not useing the sun out part of the rca on the head unit. and it sounds like crap and the sun sounds very very week. its alsomost as if i dont have a sub.
Old Oct 4, 2006 | 12:47 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: please help me wire up my amp and sub (riceball777)
Not sure but why would you say that the radio has a subwoofer output. Then say that you did not use it? Thats what its for. Now please post what your set up is. What kind of sub. And what kind of amp.
Old Oct 4, 2006 | 02:29 AM
Default Re: please help me wire up my amp and sub (wrx-killer-Sti eater)
amp is a kenwood 1000watt 2 channel
sub is a kicker comp vr 12 inch
noting happens when i use the rca's for the sub out. theres no sounds
Old Oct 4, 2006 | 04:07 AM
B18C_EJ8's Avatar
You may need to go into the menu (settings) and either turn the sub level up, or turn it on altogether...
Old Oct 4, 2006 | 10:06 AM
Odessa's Avatar
Default Re: (B18C_EJ8)
Yep, most likely your sub (output) is turned off on hu. And the reason why it sounds weak on other rca outputs, is because a crossover is set on hu. Otherwise there is no difference between which output to use.
Old Oct 4, 2006 | 10:09 AM
kroze's Avatar
from the sound of it, you are completely clueless and probably jacked up all the wiring. that's why there's no sound.
Old Oct 4, 2006 | 10:10 AM
kroze's Avatar
Default Re: please help me wire up my amp and sub (kroze)
take pics of how you wire everything up and we'll determine if it's jacked up or not.
Old Oct 4, 2006 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">amp is a kenwood 1000watt 2 channel
Hey is the sub a dual 2 ohm or dual 4 ohm? And what model kenwood amp? Not all amps can run 2 ohm mono bridge. So if you have the dual 4 ohm its not going to work depending on the amp. Also what headunit? The more information you can give us the better and quicker we can help you.
Old Oct 7, 2006 | 12:44 PM
allm0torGSR's Avatar
The "sub out" RCA only allows subwoofer frequencies to pass through it, which is exactly what you want. If you use that RCA and there's no sound...
a. The sub out is turned off in the head unit.
b. It's on, but turned all the way down.
c. The amp has internal crossovers, and you have them messed up, making the sub play full range, which will blow the sub eventually.
It sound like your sub is playing high frequencies and no bass, from what your describing. Does you amp have internal crossovers? Are there crossover switches and/or crossover buttons or ***** on the side of it? Pics would halp.
CNSK
Audio / Security / Video
17
Dec 15, 2008 12:47 AM
shawn69
15
Feb 18, 2007 06:21 PM
Mark27
Dec 6, 2005 05:35 PM
swatdog
Nov 4, 2003 02:26 PM
Racer X
11
Nov 13, 2002 08:27 PM
