Transmission seals
Old Oct 3, 2006 | 09:53 PM
peanut butter's Avatar
Default Oil where oil shouldn't be
So I just picked up a "grind free" L3 Si transmission to replace my dx unit and there is quite a bit of oil built up in the bell housing. I would assume that its coming from the main shaft area, possibly the seal for the main shaft.
How easy is this to replace? Will I have to crack the case open or is it just like replacing the axel seals? Has anyone done this before?
Old Oct 4, 2006 | 05:58 AM
Mavrick's Avatar
Default Re: Oil where oil shouldn't be (peanut butter)
it is quite nasty to replace, cracking the case open and removing both shafts. also remember it could be the engines rear main oil seal leaking as well
Old Oct 4, 2006 | 07:08 AM
Tippyman's Avatar
Built up grime is to be expected in a 15+ year old tranny. Unless it's enough where it looks like there is a serious problem, just clean it off and move on.
Old Oct 4, 2006 | 09:45 AM
Default Re: (Tippyman)
I'm not sure how to determine if its a serious problem or not. I didn't get to see the engine that it came off of either. I would say that it looks about like the outside of my engine block after 15 years of built up oil got on it. Its probably 1/8th inch thick with oil or so.
Old Oct 5, 2006 | 05:12 PM
Rex89's Avatar
Default Re: (peanut butter)
id just wipe it of and check in a week weather theres anymore buildup
mntdewred
15
Mar 1, 2006 06:46 PM
TylerC
Aug 8, 2005 08:13 AM
93hatchin
Jul 25, 2005 04:49 AM
stevescivic
Feb 8, 2005 08:14 PM
serious
Mar 24, 2003 11:38 AM
