cant put castle nut on?
if what your explaining is the ball joint......first get a helms, then you would know what to do.....you might be in luck and be able to pop it out with a 2 ton 2 arm puller......but my reccomendation would be to buy a new balljoint and take off the UCA and have Honda or another shop press in and out the ball joints, then re-install and put the car back together.......but if what your explaining is not a ball joint....please disreguard
to rethread, you need a Tap and Die specific to your application. The tap rethread holes... and the Die rethreads bolts. Looks like you only need the die. you can get it cheap if you only buy the one you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangger »</TD></TR><TR><TD CLASS="quote">to rethread, you need a Tap and Die specific to your application. The tap rethread holes... and the Die rethreads bolts. Looks like you only need the die. you can get it cheap if you only buy the one you need.
Also make sure the threads on the castle nut itself are in good shape.
Ef Whore
11
Nov 28, 2002 01:32 PM
