half size radiator in civic
can i use a half size radiator from a 92-95. i broke mine when i was pulling out the engine
. would i need any special mounts and is it hard to hook it up. reason i want to go with half size is they are cheaper and i want to run my turbo i.c piping there.
I suggest looking into a 95-99 Neon radiator. It fits better than the 92-95 Civic radiator, it almost bolts right in. If you do use a Neon radiator, make sure you get one for the non-AC model. The AC equipped Neon used a full sized radiator.
