water temp gauge and fan switch
Old Oct 3, 2006 | 08:31 PM
Nightkidef9's Avatar
Default water temp gauge and fan switch
I got an 91 Ef with a 94 gsr motor.
where do i hook up an electric water temp sender for my a gauge, and where is the fan switch. I want to run the fan all the time, but i cannot find the switch to modify it.
Old Oct 3, 2006 | 09:08 PM
4thgenhtch's Avatar
Default Re: water temp gauge and fan switch (Nightkidef9)
Its the single wire sensor under the distributor, that feeds the cluster... The fan switch should be right in the waterneck past your thermostat, Why do you want your fan always on? Your engine needs to be at its proper operating temp.. You shouldnt have any problems if your fan turns on and off with the factory sensor, Just how Honda intended
Old Oct 3, 2006 | 10:49 PM
Suck my DX's Avatar
Default Re: water temp gauge and fan switch (4thgenhtch)
ground the blue wire and splice the blk/ylw wire to the ylw/blk goijng to the dizzy...
your fan will stay on as soon as the key is put on the on position
Old Oct 3, 2006 | 11:44 PM
NikoZai's Avatar
Default Re: water temp gauge and fan switch (Suck my DX)
Huh?That's not how to make the fan stay on, nor is it how to connect the temp sensor. The yellow/green wire goes from the cluster to the sensor, opposite is ground.
See page 16-70 in the CRX Workshop Manual
http://www.norcalcrx.org/library/
At the Fan switch - you've got 2 wires, just put a paperclip or piece of wire jumping the 2 pins in that plug. wrap it with electrical tape so the wire doesn't fall out, then the fan will come on whenever the key is in the On position.
4thgenhtch is correct though, if your fan comes on when your car gets warm - it's good, leave it like that. If you're having overheating problems, either you have a leak or blown H/G or your thermostat is stuck.
Old Oct 3, 2006 | 11:52 PM
Suck my DX's Avatar
Default Re: water temp gauge and fan switch (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">Huh?That's not how to make the fan stay on, nor is it how to connect the temp sensor. The yellow/green wire goes from the cluster to the sensor, opposite is ground.
4thgenhtch is correct though, if your fan comes on when your car gets warm - it's good, leave it like that. If you're having overheating problems, either you have a leak or blown H/G or your thermostat is stuck.</TD></TR></TABLE>
either way works...
97civicdx
Jul 20, 2010 05:04 AM
rick_rabies
Engine Management and Tuning
Aug 21, 2009 05:20 AM
blaster834
Sep 16, 2004 11:52 AM
TwztdSi
Oct 17, 2003 03:27 PM
cnydelSolHybrid
May 9, 2003 02:17 PM
