drag radials or slicks worse for axles/drivetrain?
Old Oct 3, 2006 | 07:26 PM
wfocrx's Avatar
Default drag radials or slicks worse for axles/drivetrain?
I was just wondering if 1 has a higher chance of snapping an axle or busting some drivetrain piece. I know slicks "should" be more dangerous; but, I have heard that if you get wheel hop on drag radials it can be very distructive. My crx is running the full-race traction bar and stiff MM inserts, do you think I should be pretty safe from wheel hop
Old Oct 3, 2006 | 07:28 PM
E Town DSM's Avatar
Default Re: drag radials or slicks worse for axles/drivetrain? (wfocrx)
Drag radials will usually be due to wheel hop from the stiffer sidewall. A slick has a little more cushion from the softer sidewall. But also the way you drive will keep parts together preload the clutch and ride it out dont just dump it.
Old Oct 3, 2006 | 07:40 PM
wfocrx's Avatar
Default Re: drag radials or slicks worse for axles/drivetrain? (E Town DSM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Town DSM &raquo;</TD></TR><TR><TD CLASS="quote">Drag radials will usually be due to wheel hop from the stiffer sidewall. A slick has a little more cushion from the softer sidewall. But also the way you drive will keep parts together preload the clutch and ride it out dont just dump it.</TD></TR></TABLE>
I pretty much already knew that. Basically, I want to know which would be a more forgiving setup (on the drivetrain) for a person with limited experience drag racing?
TealEG!
Aug 30, 2006 07:20 AM
budget
Jan 6, 2006 08:47 AM
sykotic
Apr 7, 2005 07:15 PM
DarkBB4
Nov 22, 2004 11:44 AM
ITRswapandslow
Feb 15, 2004 07:36 AM
