SiR CRX front end question ????
Old Oct 3, 2006 | 06:37 PM
br'Y'an's Avatar
Default SiR CRX front end question ????
I was just wondering what part of the JDM radiator support will I need to make to the SiR front end conversion bolt right on ???
Old Oct 3, 2006 | 07:07 PM
bmg123's Avatar
Default Re: SiR CRX front end question ???? (br'Y'an)
I just used my existing radiator support, and used longer screws and washers to extend it out a little more for the hood to close.
From what I read, the EF8 support will not allow the hood to close perfectly either and will also require some modification. I read that the EF7 support will allow the hood to close perfectly with no modification.
Old Oct 3, 2006 | 07:46 PM
Dee's Avatar
Dee
Default Re: SiR CRX front end question ???? (bmg123)
If you are using an '89-'92 type JDM hood the '89-'92 EF6~EF8 radiator support is needed so the hood will close properly. The only piece need is the removable upper support that holds the hood latch.
What parts do you have for the front end conversion?
Old Oct 3, 2006 | 07:50 PM
menappi's Avatar
or just use washers, no point in wasting money when u can just do that.
Old Oct 3, 2006 | 07:54 PM
boosted.CRX's Avatar
Just file down the bolt holes in the EF8 T-Bar and spend a good amount of time ligning up the hood on the hinges and the latch. Thats what I did, it lines up perfect, no ugly washers or gaps and you cant even see where I filed it.
Old Oct 3, 2006 | 08:27 PM
menappi's Avatar
or that, or u can use a drill and drill them longer
Old Oct 4, 2006 | 12:15 PM
br'Y'an's Avatar
Default Re: SiR CRX front end question ???? (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">What parts do you have for the front end conversion?</TD></TR></TABLE>
I have the front bumper,hood,fenders,headlights,radiator support.
what part off the radiator support do I need ??? will I only need the part where the headlights bolt on too ???
Old Oct 5, 2006 | 02:20 PM
Not even, just the T-Bar that goes inbetween the headlights and connects down to the bottem rad support. (looks exactally like a T)
Old Oct 5, 2006 | 02:22 PM
Default Re: SiR CRX front end question ???? (SiRClay)
Also: EVERYONE INTRESTED IN DOING A JDM FRONT CONVERSION, read this!
https://honda-tech.com/zerothread?id=1700836
Silencer1503
Sep 8, 2007 08:50 PM
p3t3rxp4n
Jun 9, 2006 01:02 PM
alexdog69
13
Jan 17, 2006 05:09 PM
EF9 JAMS!!!
Dec 27, 2004 06:37 PM
rough_draft
Jun 22, 2004 05:54 PM
