Speedometer?
If there's something wrong with your VSS, your check engine light should come on. I had a problem with a worn wire.....an issue with a custom wiring harness for the JRSC install. ANyway, my speedo didn't work, but it registered on the ECU as an error for the VSS. If your check engine light isn't on (ie. the ECU is getting a signal from the VSS), then it might just be a connector problem or a guage problem....somthing in the interior of the car.
yea my check engine light did come on..... how much to get that fixed?
mikej94civex
Jan 7, 2010 03:10 PM
brentaction22
May 24, 2007 09:28 PM
steelrainwarrior
14
Nov 5, 2006 05:41 PM
