Volts dropping to 5-6 on crank, no start.. ideas?
Old Oct 3, 2006 | 05:47 PM
TylerC161's Avatar
Default Volts dropping to 5-6 on crank, no start.. ideas?
Battery just tested good 10-15 min ago at advanced auto.
Upon starting car, or, well, trying to start, the volts drop to 5-6 and car will not run.
Also tried other buddies batteries. no dice.
1992 h22a. manual.
Old Oct 3, 2006 | 06:11 PM
InvaderTrax's Avatar
alternator?
Old Oct 3, 2006 | 06:40 PM
mgags7's Avatar
so it goes down to 5-6 volts right when you try to crank it?
or does it do that when you put the key to II??
Old Oct 3, 2006 | 06:46 PM
Speedra500's Avatar
Default Re: (bb4ever)
first off, never trust advanced auto or autozone. It sounds to me like the battery is no good, you should try and test a different battery. If its not that there might be a short in your starter solenoid or starter. So the start does actually turn the motor but just not with enough force to get it started?
Old Oct 3, 2006 | 06:57 PM
TylerC161's Avatar
It dips down to 5-6 when actually cranking the engine. of which, it WILL crank, but its slow, like a dieing battery..
And we've swapped batteries with different ones out of perfectly working cars, it gets the same effect.
Old Oct 3, 2006 | 08:49 PM
mgags7's Avatar
change the starter out with a friend and see what it does.....
Old Oct 4, 2006 | 11:58 AM
Unidentified's Avatar
Default Re: Volts dropping to 5-6 on crank, no start.. ideas? (TylerC161)
I've had this problem before... It turned out it was poor grounding. Check all your ground wires.
Old Oct 4, 2006 | 12:20 PM
fastludeh22's Avatar
what happens when u roll start it? what do the volts measure with the key on 2? with it running?
Old Oct 5, 2006 | 12:57 PM
jdm_jeners's Avatar
Try doing these tests:
if u have a voltmeter connect ur positive lead to ur power cable going from the battery to ur starter then connect ur negative post to that same cable but in the starter. If u have more than .5v drooping then ur cable is bad. that could cause slow cranking.
Do the same with ur ground cable. it must not have more than .2v dropped.
* Make sure ur meter is on DC volts.
While doing these test u must be cranking the motor. Disable the distributor connections.
BTW: If mechanical resistance goes up:amperage goes down and voltage goes up.
If mechanicla resistance goes down: amperage goes up and voltage goes down.
If Electrical resistance goes up: amperage goes up and voltage goes down.
If electrical resistance goes down: amperage goes down and voltage goes up.
Modified by jdm_jeners at 2:09 PM 10/5/2006
Old Oct 5, 2006 | 01:06 PM
Finest's Avatar
Default Re: Volts dropping to 5-6 on crank, no start.. ideas? (Unidentified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unidentified &raquo;</TD></TR><TR><TD CLASS="quote">Check all your ground wires.</TD></TR></TABLE>
dot
Old Oct 5, 2006 | 05:45 PM
uLikeMyPreludeSi's Avatar
Default Re: Volts dropping to 5-6 on crank, no start.. ideas? (Finest)
starter...
JDMdb8isO
Feb 6, 2011 12:58 PM
chikin pickle
Jan 13, 2010 05:50 AM
brzrkr
Nov 25, 2007 03:51 PM
CivicBoi
11
May 27, 2002 11:30 AM
ahcjar103
Dec 9, 2001 11:37 PM
