92 accord starts cold, wont start once hot?
Bessy will start after being left alone, and out of the sun for a couple hours. But drive her until the temp rises (10 min.) and shut it off- wont start for a while. Fuel pressure is good. Tech said it might be an electrical problem down by the gas tank and pump? Any suggestions? Thanks
John
John
You really need to "catch it in the act" and see if there is power at the coil, and listen for the fuel pump to run 2-3 seconds when the key is turned on.
It could be the ignition switch is going 'south' in a handbasket.
yo check ur main relay under the dash i jus had this problem bout a few weeks ago had to fix one point on my relay circuit and it starts fine everytime, u can also check out the site cb7tuner.com they have a thread thereMAIN RELAY that will guide u step by step in order to fix that if thas it.One other thing check to see if ur fuel pump is engaging if so listen for a click sound once the check engine light goes off if not the relay isnt workin LATES
zennx2k3
Nov 12, 2008 04:03 AM
