FS: Parting out Car- DA-DC-EG "LOOK" Lots of parts that fit all vehicles
I cant get what i want for the car as a whole so i will part it out to good homes ONLY! All parts are USED unless specified as NEW and all parts are OBO.
RMF Narrow style header (mint) will include 4 wire O2 $700
JDM 2nd gen 5 million series B16 block very low miles (barely drove the car--with a single layer head gasket it was 245 across the board as far as compression went) with ARP head studs new water pump and timing belt $500
JDM Carbon/Kevlar Race Bucket Seat w/side mount brackets (dont remember brand/best seat ive seen around in awhile) $500
TWM 2000 series ITB's 52mm w/Carbon Bells with built in vacumm accumalator. and fuel rail with regulator, and TPS. B-series Vtec B16 or Type-R used for a day never driven with them on. 1 thing they have been welded on the end because UPS cracked it during shipping and wouldnt cover it. So i had it professionally welded and had the flange re-surfaced for straightness. They fit nice and are nice sounding. Will include HONDATA intake manifold gasket with it. $1000
K-Sport Full adjustable coilovers for Integra or Civic. i have Type-R lower strut mounts on them now but will include regular fork style strut mounts whoever buys depending on what they want. Used 500 miles if that. $500
Complete OEM 01 Integra Type-R cylinder head complete with rockers, oil rails, lost motin assemblies, Fererra valves-springs-and titanium retainers. (NO CAMS-but if bought togehter will give discount. Includes Vtec solenoid also. $900
Skunk2 Stage 2 cams (cam journals have been micropolished for less friction) $500
JG Black adjustable cam gears used maybe 500 miles if that $150 if bought with cams $100
JDM DA Integra front bumper support $100
JDM DA Integra (RARE 4DR) rear bumper support $100
JDM Type-R (REAL) shift **** $80
RC Engineering 440cc OBD1 Injectors (never driven on, only started) $250
Clutchmasters Stage 3 pressure plate (2000 miles) with ACT 6 puck disc (maybe 500 miles) larger spline trannies (92-01 integra b-series) $250
JDM Kaiten 8lb flywheel B-series $150
JDM Amber Bumper lights 90-91 Integra $30
Carbon fiber rear gas tank cover 90-93 integra $70
OBD1 B-series Vtec distributor $100
Sparco DA Integra 90-93 drivers side seat bracket with sliders $100
Sparco steering wheel (cant remember the name) black suede with optional ring and horn button $150
MOMO steering hub adapter for 90-93 integras may fit other cars $50
JDM Type-R rear lower control arms with PROTHANE BUSHINGS $100
Aeromotive fuel filter with AN fittings 10 microns filtering $50
Polished B-series valve cover $60
99-00 Civic SI Valve cover mint $60
NGK blue plug wires DOHC Vtec $30
B&M Universal oil cooler NEW IN BOX NEVER USED $60
JDM 4dr Rear tailights best set ive seen $50
90-91 Integra motor mounts all 4 with inserts and the mounts are still good even without the inserts $100
90-93 Integra 4dr (RARE) trunk lip spoiler 9soft to touch OEM) $150
AZ Race machine drivers side custom mount bracket polished aluminum (fits all 90-91 integras and all 88-91 civic crxs running a b-series swap) $50
90-93 Integra shift linkage with polyurethane bushings $50
B-series 5speed starter $50
90-91 Integra B-series Alternator with (RED) AEM Pulley (works good) $50
90-91 Integra B-series Alternator OEM (works good) $40
Single belt crank pulley billet aluminum (SRD Brand) $40
STR Rear Diffuser (split style fits cars with license plate in bumper) Polished $80
All four window glass (drivers, passenger, rear driver, rear passenger) $25 a piece
Suspension Techniques rear adjustable TOE Adjusters (rare and expensive little piece) $100
JDM RHD turn signal combo switch and steering column cover. (different little piece that no one has, allows for the wipers and headlights to be flip flopped like in JAPAN. To turn on the headlights you have to use your right hadn now and turn on the wipers you use your left. Takes time to get used to). $50
SK7 5speed intermediate shaft (bought brand new about 5000 miles ago, nice clean shape) $60
90-93 Integra Clutch cable. Recently replaced only has about 5000 miles on it not stretched at all $20
90-93 Integra Clutch cable brackets (bolt to valve cover) for DOHC Vtec Engines (different from LS) hard to find $20
Modified by jefferyg32 at 12:23 PM 11/16/2006
Stuff added and eveything is OBO. Please make an offer no reasonable offer will be refused.
Anyone wants pics of certain items just send me your email address and ill forward you pics. Some reason it doesnt allow me to post pics on here. Nor am i going to waste time and try to post pics on here. Its easier for me to email them to you. Anyone feel free to post up pics that i send you if you want i dont mind.
89civich22
Nov 2, 2005 11:38 PM
