slow seape/leak from cam seal on B18C1.
Old Oct 3, 2006 | 02:51 PM
R1_Owner's Avatar
Default slow seape/leak from cam seal on B18C1.
Hey all...
... I have a gsr swapped into my '00 em1, and I have a very slow leak from the cam seal. The guy I got the motor from put in a BDL cam seal in. It is not leaking bad enough to "lose" oil, but it is enough to dirty the side of the motor a little every after a few days. Not enough to cause smoke or a bad smell though.
Should I call up honda and just order a factory one, or take this one out and reinstall it with some "honda-bond"??
Any thoughts/suggestions?
thanks again for the help, everyone.
Old Oct 3, 2006 | 02:53 PM
YodajdmEK4's Avatar
Default Re: slow seape/leak from cam seal on B18C1. (R1_Owner)
Just replace it, they arent expensive.
Old Oct 3, 2006 | 02:55 PM
R1_Owner's Avatar
Default Re: slow seape/leak from cam seal on B18C1. (YodajdmEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YodajdmEK4 &raquo;</TD></TR><TR><TD CLASS="quote">Just replace it, they arent expensive.</TD></TR></TABLE>
go back to OEM?? or get one from someone like BDL or ROBEAR??
Thoughts??
Old Oct 3, 2006 | 03:16 PM
R1_Owner's Avatar
While I'm doing the cam seal, should I go ahead and pick up a vavle cover gasket/gromit kit and swap those out??
Old Oct 3, 2006 | 05:01 PM
R1_Owner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1_Owner &raquo;</TD></TR><TR><TD CLASS="quote">
Thoughts??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R1_Owner &raquo;</TD></TR><TR><TD CLASS="quote">While I'm doing the cam seal, should I go ahead and pick up a vavle cover gasket/gromit kit and swap those out??
anyone??
Old Oct 3, 2006 | 05:03 PM
vlc92189's Avatar
it wouldnt hurt???? just get oem unless you wanna get robear or other.
Old Oct 3, 2006 | 05:06 PM
R1_Owner's Avatar
Default Re: (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">it wouldnt hurt???? just get oem unless you wanna get robear or other. </TD></TR></TABLE>
I just figured, the cam seal, vavle cover gasket, and gromets are all not too expensive (even direct through HONDA). So, I suppose I will go order all of it and make an afternoon out of pulling, replacing, and cleaning up the bay.
Thanks for the advice.
itzyaboyzeem03
Nov 2, 2008 01:47 AM
Out of every "game"
Apr 16, 2006 02:14 PM
IVI
May 2, 2005 02:26 PM
DefiantGSR
Feb 20, 2004 08:43 PM
KTeller8
Nov 11, 2002 02:16 PM
