All the dashlights stoped working including climate control...
I tried to the do the LED swap and thats were everything went to ****. The owner before me hacked up the dimmer switch wiring and used some weird connectors to connect to the dimmer switch and used butt connectors. So after I changed the bulbs, noting comes on. Now i only changed the 194 bulbs and there were 3 of them. After that didnt work, i put the old ones back on but still no luck. but then i looked at fuses and it was blown. i replaced it but still no luck. Its got all new bulbs in it, dimmer switch is properly wired, and new fuses, so what else can it be.
Ohh btw, i lit up for like 2 seconds then went out so i dont know if that helps any.
doubleoazn03
Feb 24, 2009 08:31 PM
eghatchomar
Mar 28, 2005 08:07 PM
Kevedge
Aug 19, 2004 01:40 AM
