No spark, could this be caused by the main relay?
I trouble shot the distributor and then went ahead and replaced the dizzy still no spark! could this be the main relay? Fuses are good, can't figure this out. Please help!
a little detail about engine setup and swap or not would help.....
its usually the ignitor. little grey box that looks like its from star wars, usually on the firewall.....
Stock engine, no upgrades. I thought ignitor was in the distributor. Car is an 89 CRX Si but engine is a d15a2 obd0 I think.
I'm not sure to your answer, but a lot of ef's have problems with their main relays keeping them from starting. My old 89 dx did it, my dads 4dr 89 dx does it sometimes, but my 91 Si does not. Hopefully it never does. That **** was annoying. Good luck.
i have the same problem in mywit my zc in 88 civic. firstr my mecahnic said nits the fuel pump relay by jus listgening to the cranking, then today car doesnot start becuz there is no spark, or maybe its bad wires? wat cud it be and how do u find out if the distributor is fried?
How did you verify that there is no spark? And no, a bad main relay on your vehicle will not cause a no spark condition. Did your "rebuilt" dizzy come with a new ignitor (inside distributor), coil (inside distributor), cap, and rotor. If your dizz came with all new components and you have power to the coil something is deffinetly fishy. Also take a look at the tach when your cranking the car. if the is dle jumping a little say 0 -10 rpm then your ignitor is o.k. and that if you do in fact ahve a no spark condition it is usally from a bad coil. but I would like to know how you verfified that you have a no spark condition.
i took oout one wire, and held it 2 cm away from the valve cover to see if there is gona be any electrical spark, while another person was cranking the motor. ! but there wasnot.
so u think replacoing the distributor wud be a good idea? because im facing the option of towing the car to a mechanic or doing it myself, i jus dont want to spend too much unnecesary money. if u say its the distributor i will go and buy one.
I didn't say ithe dizzy was causing a no start. Just try this diagnosis: Crank the car over and watch the tach, wait, do you have a tach in the gauge cluster? Well if you do it should jump slightly when cranking if it doesn't its the ignitor. If it does jump it is most likely the coil, if you have power to the coil which you said you did I i'm correct. Also take the dizzy cap of and do a visual inspection. And i wouldn't buy a new dizzy unless you are going to have that motor for along time, i.e. no swap plans. Just go to the junk yard and get a distributor or maybe just the coil and you could practice the removal procedure on the junk yards car.
well heres a nostart write up i just took a glanced at it and it looks alright but i hope you find the problem oh i was reading one of the of the no start topics one guy said his car fired right up after he replaced his fuse wire but anyway heres that no start write up
https://honda-tech.com/zerothread/1483855
CR-Ricks
Jul 17, 2013 03:09 PM
boostmyda
Jun 2, 2010 07:08 PM
chicows18
21
Jan 16, 2008 09:30 AM
